Tripac Apu smoking
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Alexp2686, Oct 27, 2020.
  1. Alexp2686
    Alexp2686 Light Load Member
    69
    36
    Jun 10, 2020
    I Just purchased a truck 2 months ago and it came with a tripac evolution. I was out for 2 weeks and it seemed to work fine heat and cool, but my last day out I turned the AC on and went to bed then my bunk started smelling funny almost like the smell of fireworks so I turned it off and when I checkd the apu outside it was smoking from the side where the belt is and it was really hot when i turned the switch to off I could feel the heat on my hand.
    Idk if its electrical or something else, Does anyone know what could be the problem?
    D.Tibbitt and truckdriver31 Thank this.
  3. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    take covers off then advise
  4. Judge
    92,114
    My advice.
    Don’t turn it on, it’ll smoke up the environment and be bad on the kids.
    2. Don’t touch it, it’s probably hot.
    Turn off master switch go to Thermoking in Little Rock, got a guy there that’s good on them.
    stillwurkin, Alexp2686 and D.Tibbitt Thank this.
  5. D.Tibbitt
    157,128
    Could be a burned up alternator . Does it still work properly ? Charge batteries ? Run ac/bunk heat ?
    Alexp2686 and truckdriver31 Thank this.
  6. Alexp2686
    69
    36
    Jun 10, 2020
    I was tginking it could be the alternator cause of the smell. It does turn on, but as far as charging the batteries idk, I turned it on this morning to see if it would start for 1 second and as soon as it started i shut it off. Before this happened everything was working fine ac and heat even when it happened it was blowing ice cold all it did was smell kind of like fireworks when you light them. After that smell i jumped out of the truck opened the apu and saw smoke coming from the belt area so I turned the master switch off and grabbed my extinguisher thinking there was gonna be a fire.
    D.Tibbitt Thanks this.
  7. D.Tibbitt
    157,128
    Take off the covers and take a look. There is only 3 pulleys back there for the belt. Alternator ,ac, and the crank. Maybe belt is rubbing or something . Take some pics while ur in there too
    Alexp2686 Thanks this.
  8. Alexp2686
    69
    36
    Jun 10, 2020
    Would be nice if its just the belt rubbing something. The trucks in the shop, but Ill drive up there tomorrow and take some pics. Thank you
  9. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Does it have a dpf that might’ve Been doing a burn
  10. Alexp2686
    69
    36
    Jun 10, 2020
    Im not sure how would I find that out? I just got this truck. I wasnt able to get the cover off today the mechanic had it in the garage all day, but should be able to tomorrow morning.
  11. Alexp2686
    69
    36
    Jun 10, 2020
    I just googled it and no it does not.
    magoo68 Thanks this.
