Truck maintenance
Discussion in 'Ask An Owner Operator' started by krazzyboi_44, Nov 25, 2018.
  1. krazzyboi_44
    krazzyboi_44 Light Load Member
    298
    42
    Apr 30, 2008
    BAton Rouge,Louisiana
    Whats up guys im currently leasing a 2014 386 pete the truck have 511,000 miles. I will be able to purchase the truck in June for $25,000. What kind of maintenance can i do to ensure that the truck continue to run problem free? If i can get it to last about 2 or 3 years i'll be happy with that. That will give me enough time to save for my dream truck which is a 389.
  3. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Care to share any information like motor transmissions differential apu maybe type of operations you do with the truck you asked for advice if you want it to last and be problems free don't start it
    Rideandrepair Thanks this.
  4. Ridgeline
    22,741
    123,657
    What was done before?
    this is an important question that needs to be answered before yours can even be approached.
    Rideandrepair and I glide 47 Thank this.
  5. blairandgretchen
    13,964
    76,789
    Dec 9, 2011
    South west Missouri
    Laboratory oil samples - as in, right NOW.
  6. 86scotty
    86scotty Road Train Member
    4,718
    12,960
    Aug 27, 2017
    Appalachia
    Is this a serious question? If so, the answer is everything it needs when or before it needs it. If you aren't sure of what that is then have about $30k saved and be ready for anything. No one can tell you what might go wrong with your equipment, they can only guess.
  7. Pedigreed Bulldog
    7,737
    14,424
    May 7, 2011
    2-3 years is all you're expecting out of a 2014? My truck was older than that when I bought it...and that was over 10 years ago.
    Change the oil regularly. Grease the chassis often. Do this yourself, and take the opportunity to go over the truck with a fine tooth comb every time you service it. Replace stuff that's showing signs of wear BEFORE it breaks.
    It really isn't all that hard to do. The more you can do yourself, the easier it is to keep on top of what all needs to happen and when.
    OldeSkool, PE_T, Rideandrepair and 2 others Thank this.
  8. JonJon78
    JonJon78 Road Train Member
    7,242
    43,050
    Jul 1, 2018
    What stuff that shows signs of wear is good to replace before it breaks?
  9. Gdog66223
    Gdog66223 Road Train Member
    1,871
    2,569
    Dec 30, 2017
    Coal Town
    not to brow beat but the first wrong word in this ENTIRE post is lease....
    I glide 47 Thanks this.
  10. I glide 47
    1,426
    1,523
    Jun 3, 2017
    I didn't want to be the first to say that. But never never never lease purchase no never never never lease purchase did I say never never lease purchase, okay I m done best of luck
    PE_T Thanks this.
  11. Rideandrepair
    17,572
    56,924
    Aug 8, 2015
    Regular maintenance pms belts shocks every year Ideally.Hoses Flush and keep antifreeze dca levels correct. Otherwise xtra costs batteries alternator tires and brakes ofcourse. After 700 k usually fan-turbo- air conditioner as needed the list goes on add expected emmission maintenance/ repairs as needed.Youll have plenty of costs even if only average repairs are needed.$10k a yr over a 4 yr period is very likely maybe more. Then thousands for overhaul if kept longer at least a clutch if not a re man trans. You’ll have no problem deciding what to do with any extra money if any you manage to save
    PE_T, adayrider and JonJon78 Thank this.
