Truck wont start
Discussion in 'Volvo Forum' started by dphillips, Dec 29, 2015.
  1. dphillips
    dphillips Light Load Member
    82
    8
    May 14, 2013
    I have a 2007 Volvo 670 with a cummins isx. so I'm driving no problem I come to a stop I make a turn theres no response in the peddle for 2 seconds. then its ok so I drive to a shop.the guys not there will be in later ok so as I sit there in idle all of a sudden the truck almost cuts off a check vehicle ecu comes on.i leave he calls says the truck wont come on he thinks I'm low on fuel I put 10 gallons in still wont come on. batteries have a lot of corrosion I'm thinking the ecu isn't getting power he says it might be a fuel or air issue. the truck had sat for 4 days prior for holidays and its cold in the Chicagoland thanks.
  3. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    If you're at a shop they should be able to figure out what the problem is
  4. 77fib77
    77fib77 Road Train Member
    11,764
    77,985
    Jul 7, 2010
    St Louis
    Does it turn over?
  5. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    Address the obvious and correct, then move on with diagnosis if no results.
  6. mitmaks
    mitmaks Road Train Member
    2,592
    2,113
    May 16, 2014
    You said lots of corrosion on batteries, I'd have them cleaned up first and put some terminal protectors/dielectric grease on terminals and go from there. CEL light should give you a code and you can go from there.
  7. reefer101
    reefer101 Medium Load Member
    444
    246
    Oct 24, 2014
    check the wire from battery to ecm
  8. powerhousescott
    powerhousescott Medium Load Member
    496
    499
    Jun 17, 2015
    Pecuiar, MO
    Good advice the corrosion will send a fault to the ECM and ECU. Also check the fuse at the terminal.
  9. NavigatorWife
    NavigatorWife Road Train Member
    2,937
    2,081
    Apr 30, 2012
    Cental West, AL
    Try unhooking the batteries and leave off for about 10 min where it will reset the internal computers. Clean up the terminals as posted above. See if that helps.
  10. dphillips
    82
    8
    May 14, 2013
    Im thinking there must've been 2 problems at once. i went back to the truck and cleaned off the batteries and replace the fuses on the batteries and the truck started.it ran for about 3 minutes and cut it self off. i was able to start it again. but my truck doesn't cut off in idel so now im waiting on the machenic to figure out the problem.
    NavigatorWife Thanks this.
  11. powerhousescott
    496
    499
    Jun 17, 2015
    Pecuiar, MO
    Ok, this is going to sound stupid. Check the oil level, the coolant level. I have had guys have the same issue and the truck was sitting on a slope and all it needed was just a little oil or coolant.
