Trucker ingenuity,,trooper doesn't buy it.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 201, Jan 29, 2020.
  1. 201
    201 Road Train Member
    12,840
    26,433
    Apr 16, 2014
    high plains colorado
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    They should come to the USA, go get inspected once every 10 years or so.
    Rideandrepair, Upinsmoke and 201 Thank this.
  4. 201
    12,840
    26,433
    Apr 16, 2014
    Gotta get an "attaboy" for trying to get 'er home,,quite frankly, I'd try the same thing.
    PE_T, Rideandrepair, mtoo and 4 others Thank this.
  5. asphaltreptile311
    asphaltreptile311 Road Train Member
    1,480
    2,847
    Jun 16, 2016
    What would be the penalty if you got with something like that in California
  6. 201
    12,840
    26,433
    Apr 16, 2014
    Reopen Alcatraz just for them,,
  7. asphaltreptile311
    1,480
    2,847
    Jun 16, 2016
    They'd probably cut you into pieces
    PE_T, Rideandrepair, Upinsmoke and 2 others Thank this.
  8. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    PE_T, Rideandrepair, D.Tibbitt and 2 others Thank this.
  9. x1Heavy
    34,016
    42,144
    Mar 5, 2016
    I have done things close to that a time or two. Using better materials than what that one did. You would not believe how easy it is to get a sick truck rolling for a little while.
    PE_T, Rideandrepair, mtoo and 2 others Thank this.
  10. Bean Jr.
    Bean Jr. Road Train Member
    5,575
    9,940
    Mar 30, 2014
    Frustrated reading the article. The wire holding up the tierod is because the balljoint is broken. There is no "its leaf springs wired to a suspension component that shouldn't be dangling loose (we've seen that before with the world's worst custom exhaust). Presumably, the hanger visible just inches to the right of the wires has failed, potentially due to rust."
    Rideandrepair, Troy_, stwik and 2 others Thank this.
  11. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
