Truly Understand the Pre-Trip
Discussion in 'Questions From New Drivers' started by Wasted Thyme, Sep 2, 2020.
  1. Wasted Thyme
    7,729
    38,310
    Jan 27, 2020
    GOAT watching
    Morning all. I have studied and understand what is being looked for to pass the test. But what I'd really like to understand is the mechanics behind it.
    Example: "thumping" the tires. Exactly how does that tell you that they are properly inflated?
    singlescrewshaker, alds and clausland Thank this.
  3. clausland
    clausland Road Train Member
    1,933
    11,068
    Dec 5, 2014
    North Woods
    Thumping's old school, get a thumper, no, don't buy one, get a simple tire iron and thump a tire you know is properly inflated, then thump one low on air. You'll feel the difference and the sound it makes. Years ago, the man only cared that it wasn't flat, now they get anal if one is 110# and it's twin is 70#. From an O/O perspective, tires aint cheap, so to run 'em low means you'll be replacing 'em sooner...
  4. Snoopycda
    Snoopycda Medium Load Member
    361
    715
    Jan 22, 2016
    Edmonton Ab.
    Short answer is; It does not. If you are hitting the tires on their face and with some authority you might hear a difference between the two to alert as to their pressure variation. That is if they are the same make of tire, of course.Then you pull out the tire gauge (that you always have?) and check them.
  5. Judge
    92,787
    You gotta hit something to remain calm, dispatcher, DMs, DBLs, shop foreman that knows nothing all get lawsuits.
    Tires do not.
    But on a more serious note, you’ll hear/feel the difference on a tire say 100lb then an 80 lb one.
    Some want you to gauge them, now just fuel at loves, get tire pass points and they gauge and add air pressure to them while you fuel.
  6. Biomagnum
    Biomagnum Light Load Member
    68
    135
    Jun 7, 2013
    I thump the tires as well, like Clausland said. I also look at every tire to see if the sidewalk bulge looks the same. If they are not, I check the pressure. I check again after I hook up a trailer.
    Checking the tires at every stop goes a long way to keep from having problems. Check them for heat especially.
    You can also spot a low tire on a trailer by checking them before you hook up if the trailer has auto-inflation.
  7. singlescrewshaker
    4,896
    42,908
    Dec 31, 2017
    Little Havana, FL
    To pass the pre trip, in FL CDL A exam anyway, you have to state out loud to the inspector. "I'm checking the tires pressure with a guage for proper inflation." At least that's how mine went anyway..
    Thumping is what I do every time I stop for a load check during the day, for the night, & when I take off after my 10. I thump with my bare fist. Drive & trailer. Look at steers for sidewall bulge. If a tire is low, I will find it like this. The vibration in my bones, & sound is what I'm looking/listening for. Sometimes on uneven ground I hear the "thud" slightly off. Pull forward or back a few feet & try again. Also looking for shrapnel in the tire if the "thud" is off. Off a 2nd time, no shrapnel found, the guage comes out..
    I also run the same equipment day in, day out so it may not work as well for trailer swaps..
  8. Wasted Thyme
    7,729
    38,310
    Jan 27, 2020
    GOAT watching
    Ty all. Great info. But I think I hampered my own question with my example. I really mean all of the mechanics. Minus the electronic stuff. Not the "pass the test" answers. But the what should I really be looking for on the TT.
    singlescrewshaker Thanks this.
  9. Cat sdp
    Cat sdp . .
    21,320
    76,354
    Apr 8, 2012
    Orion's Belt
    Always look under it for puddles every time you get out........tires too.
    Lug nuts , wheels every day. Oil level every day/ coolant is easy just look in the jug while Hood is up.
    And listen for air leaks when ever you park and it’s quiet.......
    It’s a little different when you’ve had the same truck / trailer for 10 years and your the only one who drives it.......
    I’d probably fail the pretrip test at the dmv.....
  10. Hazmat Cat
    Hazmat Cat Medium Load Member
    636
    1,778
    Oct 18, 2019
    Question wasn’t properly pre tripped so all responses are just people talking about thumping.
  11. singlescrewshaker
    4,896
    42,908
    Dec 31, 2017
    Little Havana, FL
    What I personally really do everyday might be considered overkill, but I drive a 28 year old truck..
    So other than tires we spoke of..
    -Gloves on hood up
    -Scanning for leaks or anything out of place.
    -Pull the puke tank cap & look at coolant level as mine is steel & not see through plastic like new trucks. .
    -Yank on the tie rods, drag link, pitman arm, steering shaft looking for play in the bushings
    -Scan the drums for oil, no cracks & shoes look good
    -scan the leaf pack, u bolts, hangers, & frame for cracks
    -check tension of fan & alt/ac belt. No auto tensioner so they need manually tighten time to time.
    -check oil level
    -start truck, flip on lights & 4 ways
    -walk around front checking lights, & latch hood shut
    -start down the ditch side now looking for exhaust leaks & at the frame for cracks
    -look at air lines for any spot they can "chafe" That's a favorite write up
    -check over rear suspension, tires, brakes, 5th wheel mount
    -down trailer for lights, frame, load still secure, listening for air leaks
    -trailer tires, brakes, suspension
    -go around back all lights are working, no lenses cracked
    -repeat trailer inspection road side up to the 5th wheel
    -ISO pigtail, & gladhands secure
    -check apron for cracks, 5th jaw is locked around kingpin
    -5th wheel pedestal no cracks, tires, brakes, air bags, suspension
    -drain air tanks, check road side exhaust
    -pull forward few ft & pull the johnson bar to check trailer brakes
    -stomp foot brake hard 2 times & hold few seconds to make sure no air leaks under hard brake
    -Roll out
    Might have missed something, hard to write up & keep my thoughts together. But that's the jist of what I do. If it looks like rain in the AM, I do this when I stop for the night. Then just check lights, tires, load secured, no puddle under the truck, 5th jaws..
