Turbo leaking air
Discussion in 'Volvo Forum' started by Tmurphy55, Nov 11, 2024.
  1. Tmurphy55
    Tmurphy55 Bobtail Member
    4
    Nov 11, 2024
    Detroit 12.7 171702 turbo, pretty new and I’m only getting 20 pounds of boost. I’ve checked all the air connections on the truck and fine, a new air cooler has been put on it, can’t find the leak still?
    blairandgretchen Thanks this.
  3. Big Road Skateboard
    7,098
    40,287
    May 2, 2021
    Intake gaskets, air supply hose for compressor, exhaust manifold leaks, turbo mounting gasket/leaks
  4. Tmurphy55
    4
    Nov 11, 2024
    None of those
  5. Big Road Skateboard
    7,098
    40,287
    May 2, 2021
    Then you're not getting fuel, or air, or your reply is in error.
    I'm betting the latter
  6. Tmurphy55
    4
    Nov 11, 2024
    I’m thinking fuel
  7. blairandgretchen
    13,933
    76,587
    Dec 9, 2011
    South west Missouri
    Problem just occur? What's your normal boost?
    I have '95 with same turbo - pegs 38-40 in dense air, easy 36 most other times.
    What tests have you run - bubbly spray boots and CAC etc?
  8. Tmurphy55
    4
    Nov 11, 2024
    I think something is wrong with the ecm to not give it enough fuel
