Urgent help: in cab airline!
Discussion in 'Questions From New Drivers' started by Penumbra, Jan 23, 2020.
  1. Penumbra
    Penumbra Medium Load Member
    305
    528
    Jul 29, 2019
    So! For some reason after multiple months my genius dog decided that chewing on the airline under my seat seemed like a good idea
    I’ve taped where the leak is, but it’s not working, tons of air leaking out. What do I do?!?
    I just need a quick fix hat that’ll last a few days until I can get home
    blairandgretchen Thanks this.
  3. sirjeff
    sirjeff Medium Load Member
    Vice grips will work best
    Or cut the line and fold it over itself so it pinches and tape around the fold
    Or go pick up a couple ferrals from a repair shop (the little brass pinch inserts inside that t fitting) take it apart and cut off the section of damaged line and refit. Will cost you maybe $1 and take 5 mins if you have a couple wrenches
  4. Cabinover101
    Cabinover101 Heavy Load Member
    726
    1,166
    Jul 28, 2019
    What he said ^^^^ Cut out the bad part, undo the nut where your air gun is spliced in and replace the ferrals, bolt back together.
    rachi and blairandgretchen Thank this.
  5. Cabinover101
    726
    1,166
    Jul 28, 2019
  6. blairandgretchen
    13,973
    76,850
    Dec 9, 2011
    South west Missouri
    Vice grips, or pinch, bend, fold and tape - anything to stem the flow.
    Any Napa or O’reillys should have fittings to repair. You’ll need 1/2” and 9/16” wrenches from memory for the brass fittings.
  7. flybynight12
    flybynight12 Medium Load Member
    683
    539
    Jan 10, 2015
    slc
    Flex seal they cut a boat in half
    birdman52, Hazmat Cat and Cabinover101 Thank this.
  8. Penumbra
    305
    528
    Jul 29, 2019
    Ok so the leak has been temporarily dealt with. The entire brass fitting was going so I essentially cut the gun out and taped up both ends until I can get to a shop.
    however that also killed the air for my seat so I’m pretty much sitting on the floor
  9. Cabinover101
    726
    1,166
    Jul 28, 2019
  10. Penumbra
    305
    528
    Jul 29, 2019
    Yep...yes indeed here’s my eve level...
  11. Cabinover101
    726
    1,166
    Jul 28, 2019
    Be Careful
