Useful hand tools and supplies
Discussion in 'Questions From New Drivers' started by cmc308, Nov 4, 2012.
  1. cmc308
    cmc308 Light Load Member
    124
    14
    Oct 24, 2012
    Houston, Tx
    What sort of hand tools and related supplies are useful for any trucker, most notably a flatbed trucker, company man or o/o? I realize O/O's will likely carry far more tools than a company man, however, I cannot visualize any situation where a few select tools could not be very handy for a company man.
    1. I understand the tape measure and screwdrivers, and it is understood about straps and common cargo blocking related supplies. Although, a thorough expansion on this topic will be greatly appreciated.
    2. As far as useful cargo securement related supplies are concerned.... I would be interested in knowing whether excess blocking bracing and cribbing is provided for by a shipper who is shipping an "odd" shaped part? Or if the driver is responsible for this thereby creating a need for hammer and a lot of nails for a trailer with a wood cargo bed? The main focus of my question here is geared toward useful hand tools for affecting a minor roadside repair if necessary. Is it a good idea to carry a large mechanics tool set? Also, I would like to know some differing views regarding out of the ordinary "blocking", "bracing", and/or "framing" a commodity for various reasons. Please advise a newbie.
  3. pinball wizard
    pinball wizard Bobtail Member
    7
    Nov 4, 2012
    Little Rock ,Ar
    For flat bed loads, a claw hammer and large pribar/ wrecking bar is a must. most shippers will build any bracing on your trailer, but you will need tools to remove them after delivery. Most floors are oak and it is hard to pull nails out. I also carry a cheep 1/4 3/8 socket set and a set of end wrenches and a adj wrench
    cmc308 Thanks this.
  4. cmc308
    124
    14
    Oct 24, 2012
    Houston, Tx
    Noted. I will add those tools to my box.
  5. road_runner
    road_runner Road Train Member
    3,582
    9,223
    Mar 26, 2012
    Montucky
    When I used to flatbed, I always carried a 4 ft piece of pipe (cheated bar) for my snap binders.
    Also useful for fending off wild dogs and lot lizzards.
    cmc308 Thanks this.
  6. Numb
    Numb Crusty Curmudgeon
    4,372
    10,416
    Jan 30, 2012
    Charlotte, N.Carolina
    company van driver here. got the same as "pinball" said. also screw drivers, pliers and vise grips, different sizes. I use them to pull nails out of tires before they get in too far. also asked shop for some extra fuses. no sense sitting waiting for a repair truck for some 50 cent fuse of an oddball size.
    also most companies don't want you doing a whole of work on the truck. lol. somebody can really screw it up.
    cmc308 Thanks this.
  7. Lonesome
    Lonesome Mr. Sarcasm
    11,807
    24,679
    Dec 15, 2007
    Northern Indiana
    I have a couple of flat blade, and phillips screwdrivers, couple of different sizes of pliers, pair of vise grips, 3/8 socket set, hammer, adjustable wrench, and a set of wrenches, 3/8", to 3/4" in my toolbox.
    I'm a company driver, and most of the people I work with said "well if I break down, I'll just call in, and get paid while waiting". Well, that's nice, but if it's 0 degrees outside, the trucks not running, help is an hour or more away, and a pair of vice grips would have gotten it running again, I'm wrenching!
    48Packard, Colorato, Numb and 2 others Thank this.
  8. cmc308
    124
    14
    Oct 24, 2012
    Houston, Tx
    Understood... I ask about repairs as a company man because I understand the apprehension that companies have when it comes to some martian working on their rigs. I had a few guys try to do a roadside repair on one of our "straight trucks".... he hosed it up real good and I still had to send a wrecker after it. So, knowing how badly I wanted to "shake" that dude as hard as I could after screwing my truck up? I figured I would ask?
  9. Pedigreed Bulldog
    7,737
    14,425
    May 7, 2011
    Vice grips. Channel locks. Crescent wrenches. Slip-joint pliers. Combination wrenches...3/8" up to 1-1/8" (and metric equivalents). Screw drivers. Sockets...3/8" & 1/2" drive, add the 1/4" if you have room, but I've RARELY had a use for them on a large truck. Multi-meter & circuit test light. Wire cutters/strippers/crimpers and some miscellaneous crimp-on connectors (I prefer the ones with the heat-shrink insulation). Various hammers & mallets. Some punches & chisels. External ez-outs. Pipe wrench. Bolt cutters. Box cutter.
    The truck has a built-in air compressor, too, so you may as well take advantage of that...just put a quick-connect on your air tank and carry an air hose. 1/2" impact gun. 3/8" air-ratchet. 3/8" chuck air drill. 3" air-cutoff tool. Tire inflator. Drill bits. Spare cutoff discs.
    If you still have room in your tool box, you can carry even more. 40" long 3/4" drive breaker bar w/ a 36" cheater pipe. 3/4" drive sockets to fit your lug nuts. 20 ton bottle jack. Heavy (minimum 4 gauge, 20 foot long) jumper cables.
    Don't forget the duct tape, bailing wire, WD-40, ether, various gauges of wire, brass air fittings and splices, spare light bulbs, tire inflation gauge, valve core tool, tread depth gauge, and all of the other "miscellaneous" stuff that you might need.
    I've still probably missed 1/2 the crap I keep in that side box....I'd rather carry around the extra weight than have to pay an arm and a leg to watch someone else perform a roadside repair that I COULD have done myself IF I'd had the tools...I've actually had mechanics borrow my tools because I had something they needed that they didn't have...IN THEIR SHOP!
  10. Pedigreed Bulldog
    7,737
    14,425
    May 7, 2011
    Most companies would rather the driver not turn a wrench on their truck...but I've never received any grief from a company over my roadside repairs. If you are going to try to redneck something together, you'd better have a pretty darn good understanding of what is broke, why it broke, how it is supposed to work, and how to SAFELY either patch it together or bypass it. If you don't have a clue how the truck works, you're almost better off not having any tools with you...because you're more apt to screw it up worse than you are to actually "fix" anything. If you can SAFELY patch things together and get the truck to a shop under its own power, my experience has found that companies are glad you saved them a $500 road service call for a $0.50 part that broke. When your patch job on that $0.50 part caused damage to a $1000 part which now needs replacement, they would have preferred to just pay for that $500 road service call.
    Lonesome, cmc308 and Flip Flops Thank this.
  11. Okieron
    Okieron Crusty Okie
    1,641
    1,024
    Dec 23, 2009
    muskogee, ok
    Marker lights and light bulbs. that will save you money ask any driver that has pretripped the truck and then noticed a marker light is out later or worse the DOT notices. most company shops will give you a couple.
    cmc308 Thanks this.
