Vent Access Doors
Discussion in 'Refrigerated Trucking Forum' started by DrMethuselah, Jul 26, 2019.
  1. DrMethuselah
    DrMethuselah Bobtail Member
    Jul 26, 2019
    What are those access doors on the back of some trucks? How do they open?
  3. Zigzag777
    Zigzag777 Medium Load Member
    460
    514
    Mar 25, 2013
    Down Yonder
    They’re vent doors, usually have 2 on the front of the trailer, mounted higher up. They open and close with a refrigerator type latch handle. Used for a variety of reasons. Dry outs after a washout, get rid of bad smells from a previous load, in certain seasons and temperatures can be used to keep a load cool, without running the reefer. Mostly used on refrigerated trailers, but also used other types of trailers too, which I won’t get into here.
    x1Heavy Thanks this.
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    easy open, easy shut. Also easy sealed. (Not that it wont stop a bad actor)
    Stick a temperature dial into the back one and shut it, check it once in a while among other things.
    There is a type of reefer service called ventilated which goes with the railroads mainly until the 50's If it was not necessary to ice or have burners inside of the car bunkers. Trucking is a much smaller version of that. I did not use them often, partly because of valuable cargo inside the trailer.
    Zigzag777 Thanks this.
  5. Zigzag777
    460
    514
    Mar 25, 2013
    Down Yonder
    To X1, if someone wants into your high value trailer load, they wouldn’t be recruiting a Pygmy to get through your vent door!!! Much faster and easier to defeat your padlock, no matter what the package says when you buy one. Watch a few YouTube videos of lock pickers beating the highest security locks on the market today, brut force not needed, just an experienced picker with the right tools. I used to see armed escorts following loads of Gillette razor blades leaving Boston. Can you imagine the value of a trailer full of tiny razor blades that sell for $3 to $5 each? Do the math! Lol
  6. x1Heavy
    34,016
    42,144
    Mar 5, 2016
    I know it.
    Been in the old Jersey City where in the quiet of the night you can hear the saws. Don't take much. It was better to just stop going there. The Lombardi wasnt much better. Pretty much any place in Jersey if I tried to sleep particularly when empty, the doors would need closing come morning. Someone always gets into them. Finds nothing. Otherwise I get out of that state before stopping.
    Ive been relatively lucky with those loads. However I think two things happened some years ago, a rig carrying narcotics and nothing to draw attention to it was tracked and stripped.
    I'll say this. If they did get into the trailer they are welcome to it. There are a few items in that box thats for them.
  7. DrMethuselah
    Jul 26, 2019
    What if as a hypethitcal some one wanted out of the trailer? Would a vent be an option? I guess I should say if you wanted to load things out and you were locked in or out
    TravR1 Thanks this.
  8. TravR1
    TravR1 Road Train Member
    3,695
    9,787
    Nov 9, 2017
    TX
    Always take your charged cellphone into your reefer with you just in the off chance some idiot locks you in. My small door has an opener from the inside but doesnt seem to work.
