VIN Location...Help!!!
Discussion in 'Volvo Forum' started by Overhaulin, Oct 17, 2022.
  1. Overhaulin
    Overhaulin Bobtail Member
    20
    10
    Aug 2, 2016
    Can anyone help me locate the VIN on a 1994 Volvo/White/GMC WHL cabover. I could not locate a VIN in the drivers side door jam or the dashboard. I checked on the outside of the frame rails around the front tire on both sides and inside the near the engine as best I could, and could not find any trace of a VIN.
    I even went to a local salvage where they had an older white cabover and I found the VIN in the frame rails in about two minutes but mine are not in the same location.
    Any help would be appreciated!
    Thanks!
    tscottme Thanks this.
  3. Judge
    92,521
    three places they usually put them
    Door Jam, on fire wall,back of Cab
    But if not there check the frame.
    Overhaulin Thanks this.
  4. wichris
    wichris Road Train Member
    4,508
    9,286
    Jan 17, 2011
    If it isn't stamped on the frame i would be a little concerned.
  5. DUNE-T
    DUNE-T Road Train Member
    7,058
    17,201
    May 10, 2015
    Detroit, MI
    On newer Volvos it's stamped on the frame, kinda above the shock absorber area
  6. Overhaulin
    20
    10
    Aug 2, 2016
    Thanks wichris, I tried scraping the oil and dirt off the frame but it's a little tough to see between the engine and frame with all the air lines running through the same area.
    I did go to a local salvage yard that had an old white cabover less motor and trans, and I found the VIN on the inside of the driver's side frame rail in a minute. I hoped that would tell me where I might find it on mine, but no luck. :(
  7. wichris
    4,508
    9,286
    Jan 17, 2011
    If you just bought the truck, call the state patrol to come look at it. Had a Pete a long time ago that had the frame rail replaced due to an accident and had to have it re-stamped.
