VNL 780 Upper Bunk Window
Discussion in 'Volvo Forum' started by COFLTravlr, Dec 4, 2020.
  1. COFLTravlr
    COFLTravlr Bobtail Member
    22
    5
    Mar 28, 2018
    So I have the upper window that you can't open and both sides the seal is all cracked and soon I'm sure will start leaking. These windows are ~ $400, you have to replace the entire thing! Two questions - can someone help with how to remove these and/or anything I can seal this with that will look okay and last?
  3. Judge
    92,488
  4. COFLTravlr
    22
    5
    Mar 28, 2018
    Thanks, I thought about flex tape but not sure it can survive the beating on the outside going down the road....
  5. DUNE-T
    DUNE-T Road Train Member
    7,058
    17,201
    May 10, 2015
    Detroit, MI
    I went to Menards got some black Gorilla silicone and just glued the glass pretty much.
    Had the truck sitting next to a building and had a load bar keeping the pressure on the window glass for 24 hours.
    Seems to be holding up ok
    Snailexpress Thanks this.
  6. noworrez
    noworrez Light Load Member
    97
    142
    Aug 6, 2020
