Volvo I-Shift gear shift/slipping problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by korex_UA, Sep 13, 2019.
  1. Lpirtle
    Lpirtle Light Load Member
    254
    318
    Oct 11, 2019
    Owensboro, ky
    Just had this exact same issue with the volvo I am currently driving. Now, it was a company truck, so all I had to do was take it to a volvo dealer. Now I know why the truck did that.
    With me personally, the truck bounced around in reverse 1 just as OP described, having a loaded trailer on would make the issue blaringly obvious, but wouldn't really show up while bobtailing.
  3. Volvo.2013
    Volvo.2013 Bobtail Member
    14
    Hii how did you solve your transmission problem?
  4. Shad87
    Shad87 Bobtail Member
    Trucks takes a while to switch from 2.nd to 3rd gear (rpms keeping revving high) once it switch to 3rd the test of the gears are fine
  5. Nyc rican
    Nyc rican Bobtail Member
    i have the same problem what was the pro
  6. Nyc rican
    i have the exact same problem
    i have a semi auto eaton with clutch
    trying to figure out the problem
  7. Stringb8n
    Stringb8n Road Train Member
    1,695
    2,217
    Sep 27, 2015
    I had an issue with mine reving to shift gears. Turned out my rear motor mounts were shot. Guess it was just enough of a sag sort of that something wasn't meshing as it should.
