Weight problems of dry van load
Discussion in 'Experienced Truckers' Advice' started by Demonrogue, Aug 2, 2016.
  1. Demonrogue
    Demonrogue Light Load Member
    250
    78
    Sep 21, 2013
    Carson California
    I have the tandems all the way forward and this what the cat scale showed
    Steers 11680
    Drives 32140
    Tandems 34740
    Gross 78650
    My though was to slide the tandems back a couple of holes would this make my load legal
  3. rachi
    rachi Road Train Member
    4,246
    5,231
    Feb 25, 2010
    SoCal
    Yes, always slide toward the "problem". May have to slide back 4 holes .
  4. Demonrogue
    250
    78
    Sep 21, 2013
    Carson California
    I tried three holes and ended up having 35000 on my drives as I mention two holes because I just need the load legal and was under the impression that each hole moves about 500 lbs or so I think
  5. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    You must have moved the WRONG direction. Any trailer set movement from the original location, towards the rear of the trailer, should have lightened the trailer and added weight to the drives. 2 or 3 holes would have been fine if you had moved in the correct direction.
    MACK E-6, CrappieJunkie and tlalokay Thank this.
  6. Dave_in_AZ
    424,393
    First make sure your all the way on the scale correctly.
    Sliding back 3 holes should have done it. Slide toward the heavy. Your butt is heavy so slide back. Maybe even two holes. Not all trailers are the same each hole can be 250 to 500.
    x1Heavy, MACK E-6 and LindaPV Thank this.
  7. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    No he didn't he moved too far. He started with too much on the trailer tandems and egress up with too much on the drives. So he went the right way but went too far.
    okiedokie Thanks this.
  8. supersnackbar
    20,099
    52,627
    Aug 19, 2007
    Your Town, USA
    It depends on what trailer manufacturer. Some have smaller slider holes that are closer together...220/hole while others have bigger holes that are farther apart. 420/hole.
  9. STexan
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Yes, You're right. I misread and diagnosed between the 2 posts :confused:
  10. Demonrogue
    250
    78
    Sep 21, 2013
    Carson California
    Yeah the next time I was on the scale where it was 11222 on the steers 35020 on the drives and 32220 on the tandems and gross didn't change by much and it doesnt help much when I am using a reefer trailer for the dry van load
  11. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    Slide your 5th wheel forward one hole and your trailer tandems forward 1 hole, then weigh again.
