What’s the difference between a 6 and 10 speed ?
Discussion in 'Ask An Owner Operator' started by Luke700, Dec 1, 2021.
  1. diamondd817
    diamondd817 Light Load Member
    159
    560
    Oct 11, 2020
    I've seen Allison Automatic 6 speeds in Freightliner Cascadias.
    feldsforever Thanks this.
  3. petefan4000
    petefan4000 Light Load Member
    107
    129
    Dec 2, 2020
    6 Speed on a 18 wheeler? That's gotta be one of the most backwards things I've seen this year.
    What do drivers think of them?
  4. diamondd817
    159
    560
    Oct 11, 2020
    Depends on the engine and gearing. I drove an older FL112 extended cab that pulled like a champ, I swear you could take that thing racing. I don't remember what engine it had though. The Cascadia I drove was so, so. It definitely would have benefited from a few more gears. My biggest complaint about the Allison 6 speeds is they shift like an automatic, whereas the new 12spd autos shift like automated manuals.
  5. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    A man I new who is now passed, he had a 6 speed day cab. He used to haul his own explosives. But he never left VA.
  6. roundhouse
    roundhouse Road Train Member
    3,213
    7,339
    Jul 11, 2018
    The 6 speed is most likley synchronized, so the the newbies can get the automatic restriction removed without having to double clutch or float the gears .
    Brettj3876 Thanks this.
  7. jgarciajr40
    jgarciajr40 Medium Load Member
    696
    1,023
    Jun 18, 2016
    My first job had a 6-speed “flat nose” international it was awful. If you were not first at a red light you were waiting an entire cycle again.
    i wanna say it was a 5-spd with a low gear that you had to use every time from a stop.
  8. jgarciajr40
    696
    1,023
    Jun 18, 2016
    @petefan4000
    I had a 6-psd auto on a kenworth best transmission ever. I believe it was an Allison if I came up to say the sky bridge in Tampa I could click 3/6 and the truck would maintain 3rd gear until I manually told it to shift up. I never had to use the brakes. If I saw a yellow in the distance just coast and click 4 gear the truck would slow down and get into 4th and I could then tell it 3-2-1 and wait for it to eventually hit around 5mph and then brake.
  9. tarmadilo
    tarmadilo Road Train Member
    1,739
    4,789
    Dec 12, 2018
    I drove coach buses with that 6-speed auto, it was seriously sweet. I just checked and a fully loaded coach weighs around 60k, so there’s no reason it wouldn’t work on a semi.
