What does it mean to get a semi "flatbed ready"?
Discussion in 'Questions From New Drivers' started by Drtro, Sep 24, 2016.
  1. Drtro
    Drtro Light Load Member
    91
    28
    Sep 13, 2016
    Virginia, USA
    Was reading some threads on flat bedding and buying your own truck, and people always mentioned getting the truck "flatbed ready."
    What does that mean exactly?
  3. Gunner75
    Gunner75 Road Train Member
    5,701
    9,076
    Mar 17, 2014
    Jackson Center Ohio
    Getting all the securement gear placed, headache/ storage boxes placed, and anything else one would need or want to do flatbed
    May not be what others consider, but that's what i think ii hear that phrase
    Airborne, Captain Canuck and Longarm Thank this.
  4. Mattflat362
    Mattflat362 Road Train Member
    2,711
    6,225
    Feb 18, 2015
    Avon Lake, Ohio
    People always that? I have never heard it and have no idea what it means?
    Have you ever worked a flatbed?
    I mean it probably just means whatever you need to gather to run a load.....chains binders straps tarps coil racks dunnage...
    Airborne Thanks this.
  5. Drtro
    91
    28
    Sep 13, 2016
    Virginia, USA
    How much should one typically budget for that sort of thing?
  6. Mattflat362
    2,711
    6,225
    Feb 18, 2015
    Avon Lake, Ohio
    How big is your flat going to be? Will you be doing oversize? Tall stuff? Steel? 400+ for tarp......300 for chains/binders.....
  7. blairandgretchen
    13,932
    76,571
    Dec 9, 2011
    South west Missouri
    I dumped about 5k all in, from chains and binders to headache rack and tool boxes.
    You can get in a bit cheaper to get by.
    Lepton1, Ruthless and Longarm Thank this.
  8. Longarm
    Longarm Road Train Member
    1,292
    35,244
    Jun 2, 2011
    Don't forget a breaker bar! Hand tight won't cut it.
  9. Drtro
    91
    28
    Sep 13, 2016
    Virginia, USA
    Oh I have no idea. It will be a few years before I buy a truck and trailer of my own. I was thinking of getting a 53' flat, or do you think a step up would get more loads? Thinking of Mercer if I actually want to go the flatbed route when I go O/O. Was just curious about what "flatbed ready" meant.
    If location means anything on the type of loads you get, I'm from Virginia, so would probably be taking loads out of there, North Carolina, or Maryland, and go from there.
  10. TripleSix
    133,284
    First things first. Before buying equipment, make sure that you buy a truck with the proper wheelbase. You need room for the headache rack and any potential front overhang.
    And flats have a deeper kingpin setting than steps too.
    'What do you mean by "deeper kingpin setting", Six?
    Steps and rgns have shallow kingpin setting. 5th wheel all the way to the rear, the front drives are exposed. On a flat and a van, drives are completely covered.
    In other words running a flat might make it necessary for a longer wheelbase than a step to insure clearances.
    Measure twice. Cut once.
  11. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Flat bedding required on my end a headache rack big enough behind the sleeper to hold all chain at a minimum I think that was a 20 chain rack with bins at the bottom so you don't snare your own drive shaft and tear yourself apart.
    A slideable 5th wheel. You wont often use it but you will be happy you have it.
    A dump valve put inside your dashboard so you can cause the airbags on the trailer spread axle rear to dump it's suspension for very tight manuvering.
    A side box put on your tractor somewhere to catch the odds and ends of securement.
    A trailer capable of flatbed work fully outfitted for same. With enough storage for all of your securement, tarps, etc. If you dont have enough box to carry everything with a clean deck, get more boxes and bigger ones until you can.
    Flatbedding is a uppergraduate type of trucking. Very precise. Not as common as your van driver with a load of chips. ANyone can do a van. But special people run flatbeds or tanker.
    Last but not least... put a cup of coffee in front of your shifter on the floor of your cab, no lid.
    Drive until you can keep that coffee just so and not spill it. Congrats you are now ready to run flatbed.
    Airborne, Chewy352, RedRover and 7 others Thank this.
