What is a Steering Wheel Holder?!
Discussion in 'Questions From New Drivers' started by Hazardous, Mar 8, 2016.
  1. Hazardous
    Hazardous Light Load Member
    136
    82
    Jul 25, 2012
    I see all these people getting all bent outta shape about new drivers and "steering wheel holders"? What is that? What distinguishes a "real" driver from just another holder?
    Dominick253 Thanks this.
  3. crb
    crb Road Train Member
    1,676
    1,374
    Dec 1, 2009
    USA
    Popcorn pass the popcorn.
    If you cant answer that for yourself you are most likely steering wheel holder.
  4. AModelCat
    165,510
    I think the definition varies based on who you're talking to.
  5. FozzyNOK
    FozzyNOK Road Train Member
    2,482
    3,826
    Jul 18, 2007
    Oklahomistan
    These days a "steering wheel holder" is someone who joined the industry 15 minutes after you did..
    McCauley, n3ss, hunted and 5 others Thank this.
  6. jacquesi23
    jacquesi23 Medium Load Member
    481
    159
    Jan 21, 2013
    I would assume it's a van vs flatbed thing.
    Most van guys pretty much do just that....hold the steering wheel...while the open deck guys actually climb out of the truck to work
    Dakota Dave and Mudguppy Thank this.
  7. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Would you rather drive standard or auto?
    Mudguppy Thanks this.
  8. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    You may be a wheel holder if:
    You don't know what's under the hood
    You can't tell the difference between nutella and Rotella
    You just graduated swift school but you have a Peterbilt belt buckle and a CAT hat
  9. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,569
    Jul 15, 2006
    El Chuco, Tejas
    I have a Volvo D13 435hp engine with the XE software, Volvo I shift transmission with .78 top gear ratio and a 2.64 rear end.
    I want a cookie!
  10. Brettj3876
    11,257
    54,060
    Nov 18, 2014
    Land of local
    All about the mentality, you have a lot more under your belt than I do but I've run into a few younger guys that were far from the cookie cutter mega
    wore out and Cottonmouth85 Thank this.
  11. blairandgretchen
    14,018
    77,324
    Dec 9, 2011
    South west Missouri
