What is accepted battery draw down?
Discussion in 'Ask An Owner Operator' started by Keepforgettingmypassword, Nov 1, 2022.
  1. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    938
    Jan 11, 2022
    With the kill switch off for 12 to 20 hours?
  3. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    With no drain on them, they should be at 12.5 or 12.6, even after a week. If they are dead, even with the kill switch off, you have one that's shorted and killing the others.
    Do you have a sulfur smell coming from them when the truck is running?
  4. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    I don't have a sulfur smell but I'm having all types of electrical issuses. Instead of bouncing all around I figured I should start back at the beginning. Maybe I missed something.
    And now the batteries in the muilty meter are dead. Allow me a couple days to update.
  5. blairandgretchen
    13,932
    76,571
    Dec 9, 2011
    South west Missouri
    Load test the batteries.
    I typically change them out every 2 years , before winter, 850CCA, keep them ‘tended’ 24/7/365.
    If you have toasted lead blocks, change out alternator as well, keep it in the box for emergencies. Dead lead can kill the sparky whirly bird sometimes.
    cke, Cattleman84 and Siinman Thank this.
  6. Goodysnap
    Goodysnap Road Train Member
    3,772
    9,198
    Jul 12, 2017
    If the battery disconnect is wired correct you should have no drain with the switch off.
    I suspect you have something wired direct to the batteries causing the drain.
  7. zaroba
    zaroba Heavy Load Member
    840
    1,269
    Aug 28, 2012
    South East PA
    With the kill switch off you should be good for over a month without issue.
    Even without it turned off the batteries should *easily* last several days unless you have something like a chest freezer or household style fridge running.
    InTooDeep Thanks this.
  8. lester
    2,956
    8,085
    Jan 2, 2012
    NW, Iowa
    We have farm equipment that will sit for 9 months with no issues. You have another draw or bad batteries
    cke and Keepforgettingmypassword Thank this.
  9. lester
    2,956
    8,085
    Jan 2, 2012
    NW, Iowa
    Simple way to check for a draw. Turn battery disconnect switch off. Pull negative cables off battery. Get test light and put it between positive battery post and the unhooked negative cable. If it lights up you have a draw.
    I've done this with older cars. Test light lights up, then start pulling fuses till the light goes out. Boom found the draw
    86scotty, cke, Cattleman84 and 6 others Thank this.
  10. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Easy to do on 42 year old vehicles with no electronics.
    Not so much today.
  11. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    Went from 14.2 volts to nothing. Have the power shut off trying to let the batteries cool.just nothing.
