What percentage does fuel constitute?
Discussion in 'Ask An Owner Operator' started by JBS-PA89, Mar 26, 2020.
  1. JBS-PA89
    JBS-PA89 Bobtail Member
    8
    I am wondering if I could get some ballpark numbers from some experienced o/o's. Roughly, what percent is fuel of total revenue? So if a load pays $1000, what percent should I estimate for fuel? I appreciate any feedback. Thanks
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Never mind what the load pays. Never mind the percentage.
    Fuel is second biggest expense behind truck and trailer payment.
    You burn a certain amount by mile. IN mountain country on grades steep enough you can burn 30 gallons a hour. Which would be about 100 dollars or so ballpark.
  4. Opus
    132,398
    About 30.
    Unless you're like @blairandgretchen. But for us troglodyte dry van guys, about 30.
    x1Heavy, not4hire, Old Man and 2 others Thank this.
  5. Cat sdp
    Cat sdp . .
    21,311
    76,259
    Apr 8, 2012
    Orion's Belt
    30 is the max anything less is preferred
    not4hire and PE_T Thank this.
  6. blairandgretchen
    13,948
    76,695
    Dec 9, 2011
    South west Missouri
    Awww - you’re too kind.
    Yes, I’m not much help here. It’s been about 7% this year.
  7. Rideandrepair
    17,566
    56,910
    Aug 8, 2015
    That’s a tricky one. 25% in a normal environment seems about right. Add high fuel costs, and surcharges, it gets trickier. One would have to minus fuel surcharge, use a base cost to get an accurate %. Too often rates stay the same, surcharge goes up. All too often, Brokers will keep a % of a surcharge, booking freight at an all in price. Combine that with a bad economy, and % as high as 50% is possible on lousy paying loads. I saw a lot of that, when fuel hit $5.00 a gallon, along with dropping freight tonnage. It was a disaster.
    NorthEastTrucker and x1Heavy Thank this.
  8. lester
    2,957
    8,086
    Jan 2, 2012
    NW, Iowa
    Seems like an odd way to figure fuel cost to me or maybe I'm missing something. But if a load pays a 1000$ you only have half the information. That could be a $1000 on 50 miles or 400 miles or more. There would obviously be a large difference in your fuel cost there.
    Dino soar and Rideandrepair Thank this.
  9. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    I need to run the numbers too see if I can beat Blair
    x1Heavy Thanks this.
  10. Opus
    132,398
    don't.....I already did.....he's not lying
  11. Tug Toy
    Tug Toy Road Train Member
    7,069
    73,956
    Jul 4, 2015
    Corn field
    I think fuel is a hard cost and shouldn’t be looked at on a % of sales. Fuel cost is a hard number based on fuel price and miles run. It is irrelevant to % of sales unless your not charging enough. If it was %30 of my gross I’d jump out a window.
