When to overhaul
Discussion in 'Ask An Owner Operator' started by Pancho_24, Mar 6, 2025.
  1. Pancho_24
    Pancho_24 Bobtail Member
    11
    4
    Apr 5, 2018
    So about 10 years ago we bought a ‘98 379 with a 3406e 6ts with no maintenance history. I’ve put about 1.1mil on it since then.
    We’ve never opened up the engine with the exception of some camshaft work a few years ago. The head is not the original since it was missing the yellow paint when we bought it.
    I send in oil samples every 20k miles when I change the oil and so far they’re coming back normal.
    My question; do I keep trucking until I notice something off/starts giving troubles or is it almost time for an overhaul with the current (confirmed) miles?
  3. abyliks
    abyliks Road Train Member
    4,141
    9,767
    May 2, 2010
    ludlow MA
    It’s almost time, but until it starts using a gallon+ a day keep on trucking, unless you have a good year and are looking to spend a little something at the end to knock uncles Sam’s take down
    Ssgtkevin, Siinman, Opendeckin and 3 others Thank this.
  4. Pancho_24
    11
    4
    Apr 5, 2018
    10-4 Thank you for your reply
  5. Judge
    92,550
    If you wanna spend money just do
    rods+mains
    (everything but crank and cam)
    Opendeckin Thanks this.
  6. DUNE-T
    DUNE-T Road Train Member
    7,058
    17,201
    May 10, 2015
    Detroit, MI
    One of my N14's has been consuming a gallon of oil per week for the last 3 years. I say keep driving until it starts giving you problems
  7. bad-luck
    bad-luck Road Train Member
    3,442
    6,349
    Nov 16, 2013
    Baltimore, Maryland
    Have you had the rods and mains done?
  8. MTMAUS
    MTMAUS Light Load Member
    263
    218
    Sep 28, 2019
    I dont know much about that motor, but unless there is some hard actual known things you need to replace at a certain time etc, I aint stuffing around with a good motor, keep oil samples going and just keep trucking
  9. wore out
    wore out Numbered Classic
    17,396
    216,129
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I’d leave it be till it gave problems, I have 2 in the shop right now that we’re took some place for an ounce of prevention……..it’s gonna take 10 lbs of cure to get em back right
    Siinman Thanks this.
  10. Pancho_24
    11
    4
    Apr 5, 2018
    Well that eases my mind! Thanks for all the input
