Which diesel anti-gel
Discussion in 'Experienced Truckers' Advice' started by Ridlingdj, Nov 17, 2019.
  1. Ridlingdj
    Ridlingdj Medium Load Member
    414
    562
    Dec 12, 2018
    Well I'm going to have to go back and do some thinking I have always uses power service
  3. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    you have to double up on it. no mixed 1 and 2. i would use a bottle in each side. maybe over kill but i never gel up
    Wheeljack Thanks this.
  4. Wheeljack
    Wheeljack Light Load Member
    105
    1,051
    Sep 16, 2019
    I do the same as you and never had a problem. When it gets real cold out I double dose every time to be safe. That is with power service in the white bottle.
    truckdriver31 Thanks this.
  5. mitmaks
    mitmaks Road Train Member
    2,593
    2,115
    May 16, 2014
    I use 1 bottle 1/2gal container in each tank when it goes single digits/below zero. I have 90 gal tanks but never filled more than 130 gal when gauge shows 1/8 tank
  6. bigtravelr
    bigtravelr Light Load Member
    104
    128
    Jul 8, 2017
    My reefer gelled up in Wyoming a few weeks ago with power service. I'm definitely going to give the hot shot secrets a try
  7. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
  8. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    when i was allowed to use anti-gel, i was told specifically Howe's if i could find it, or Power Service.
    but that was far and rare to be allowed to use ANY additives. many companies i worked for, forbid us to do anything that might (in some way) cause MORE problems..we were told to always make sure to ask the fuel desk people if they had "winterized fuels"
    you'd be surprised, that Way Back in the olden days, it was not common to find winterized fuels across the southern parts of the country...
    but now (basically) many truck stops have winterized fuels. just ask, the dummy at the fuel desk.
    and if he/she points you to the roller dogs, check with the manager.
  9. Gumper
    Gumper Road Train Member
    1,579
    3,847
    Jan 7, 2018
    Butte, MT
    I suggested he do that test in the video he posted before it. Mr. Project Farm does some interesting tests.. I used PS until it gelled up on me last year, so I switched to Howe’s. Howe’s doesn’t seem to help lubricity though. Hot Shots secret or the Stanadyne looks to be the ticket. #1 fuel
    isn’t available anywhere, and most fuel stations switch to summer blend early in the spring.
  10. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    i bet if you poured the whole bottle in that 50 gallon tank it wouldnt gel
  11. Snake Farmer
    Snake Farmer Light Load Member
    56
    129
    Nov 15, 2019
    Texas
    Curious, what indicators did you see with Howe's that you didn't think it helped with lubricity Gumper?
