why can't i get over 14 volts
Discussion in 'Trucks [ Eighteen Wheelers ]' started by javelinjeff, Feb 25, 2016.
  1. javelinjeff
    javelinjeff Medium Load Member
    621
    185
    Aug 30, 2007
    victorville,ca
    Replaced alternator twice,new batteries,,truck only charges at 13.6 during the day, 13.3 with lights on,,95 Pete 379,,tried both Delco and Leece-Neville alternators,,no differece,,all wires appear good with no corroded terminals
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Is that showing on the gauge in the dash? Or have you confirmed with a multimeter?
    Mine reads 13.8 and as low as 13.5 with everything on. I think you're in the ball park.
  4. blairandgretchen
    13,937
    76,634
    Dec 9, 2011
    South west Missouri
    As above. Test guage for accuracy by using multimeter at battery, and alternator output.
    Mine runs 13.9V, you're ok I think.
  5. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    check loose ground at back of alt along with hot. especially at the crimp. check also at the starter wires going to & from. put mutli meter on back of alt hot & ground & see output. check alt belt for good tension. wires can be corroded or bad where YOU can't see them.
  6. javelinjeff
    621
    185
    Aug 30, 2007
    victorville,ca
    13.6 at alternator,13.6 at batteries with meter,,no voltage drop through cables,,
  7. wore out
    wore out Numbered Classic
    17,331
    215,237
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I don't see anything wrong with those numbers, try leaving the lights on for a few minutes to discharge the batteries just a little. (Eng off) You still want it to spin and start normal sounding. See if the gauge comes up to 14 when you start it.
    Hammer166, haycarter and truckon Thank this.
  8. KAK
    KAK Medium Load Member
    518
    2,073
    Feb 10, 2012
    Ne
    Also run a ground wire from alt. bracket to the frame
    truckon Thanks this.
  9. 062
    062 Road Train Member
    6,332
    33,971
    Oct 20, 2013
    Is the remote sense wire hooked up on back of alt?
  10. Steve62
    Steve62 Light Load Member
    170
    98
    Mar 5, 2015
    Northern BC
    have they checked the voltage reg? Most units should charge 14.4 volts on a 12 volt system. Only thing I can think of is the batteries are good fully charged and the alt. Is just maintaining. Not charging.
  11. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    13.8-14.2 is normal .
    If your Batts are full it'll go down closer to 13.8
