Why do my straps do this, and how to stop it?
Discussion in 'Flatbed Trucking Forum' started by Wespipes, Jul 22, 2020.
  1. Wespipes
    Wespipes Road Train Member
    1,037
    1,816
    Jul 14, 2019
    the dang hooks come up when I tighten the straps. I've always used the max force hooks from mytee. This time I got the flat hooks and theyre popping up 20200722_161843.jpg
    jamespmack Thanks this.
  3. Grumppy
    3,282
    11,718
    Dec 11, 2010
    West Monroe, La
    It looks like the hook is longer than the rail is. So, your pulling the strap up when you tighten it, therefore pulling the hook up also. Just what it looks like to me in that pic. Its just hard to tell at that angle.
    Numb, tommymonza, Wespipes and 6 others Thank this.
  4. skellr
    skellr Road Train Member
    8,735
    12,189
    Jul 17, 2011
    The Village, Portmeirion
    I think is from the bend in the hook. It's not as tight as your old ones.
    Can you lay them down on the deck side by side and compare?
    Wespipes, 062 and Rideandrepair Thank this.
  5. Hayfieldmn
    Hayfieldmn Light Load Member
    158
    239
    Sep 10, 2016
    why not hook them under the trailer, i don't pull flatbed anymore but when i did we used to hook under the trailer.
  6. Cat sdp
    Cat sdp . .
    21,349
    76,608
    Apr 8, 2012
    Orion's Belt
    Put the hook back down thru the rail and see how it tightens .
  7. skellr
    8,735
    12,189
    Jul 17, 2011
    I don't even wrap the hook. Just drop it down the inside and hook it on the bottom of the rail... Although, Its a PITA when its windy.
    Wespipes, jamespmack and Rideandrepair Thank this.
  8. Cattleman84
    Cattleman84 Road Train Member
    10,057
    71,983
    Nov 1, 2017
    The Sticks, Idaho
    Why are you hooking to the rub rail? Its there to protect your straps... Not to hook them to.
    I agree with @Grumppy ... The way you are hooking them, the strap lifts the hook.
  9. Tb0n3
    Tb0n3 Road Train Member
    4,788
    9,772
    Oct 5, 2012
    Earth
    Here's a tip. If you want to use the rub rail then wrap it back through one more time so the strap will be pulling the throat of the hook into the rail. Otherwise as others have said hook it under the deck.
    blairandgretchen and bryan21384 Thank this.
  10. skallagrime
    skallagrime Road Train Member
    3,855
    9,929
    Apr 10, 2012
    Indiana
    Like everyone else is saying, hook it under the lip of the deck, that's a reitenour from the look of the stake pocket extrusion, that rub rail isnt supposed to be hooked to
  11. Judge
    94,190
    Some states, Mississippi for one, will write up unsecured load for being strapped to rub railand make you restrap it.
    Seen a guy at scale house get a write up while my permit was being checked
    Crude Truckin' and Wespipes Thank this.
