Winter Gear
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by LA runner, Jan 5, 2018.
  1. LA runner
    LA runner Light Load Member
    93
    25
    Aug 1, 2017
    I have loading and unloading in - 12 plus temperatures, recently.
    Can anyone suggest a warmer,
    1) boot
    2) gloves
    and
    3) coveralls?
    Thanks for your reply and stay warm...
  3. LA runner
    93
    25
    Aug 1, 2017
    I have been...
  4. Aamcotrans
    Aamcotrans Road Train Member
    1,044
    1,803
    May 24, 2016
    Strasburg, Va
    Harley sells heated gear that work off of a battery pack if that helps.
  5. blairandgretchen
    14,016
    77,307
    Dec 9, 2011
    South west Missouri
    Long johns help a lot.
    Dan.S and Hammer166 Thank this.
  6. Hammer166
    7,621
    27,900
    Aug 18, 2007
    ~8600+' and loving it!
    The high performance synthetics, especially.
    Boots, I always used Carhartt insulated in winter, with wool socks on cold days.
    Gloves: Get some Thermastat glove liners, and then a waterproof Thinsulate glove over that. Get the heavier Thinsulate, it allows the glove to be thinner at any given warmth. Ain't cheap, but worth it. I often had two pairs so I could have one pair under the heater or exhaust.
    They make arctic weight coveralls/bibs. But they're too warm above 20° or so. Best bet is normal weight and layer underneath as needed. I prefer bibs and jacket, felt like I could move easier, and you could just throw on the jacket if you only had a vehicle or two to deal with at a stop.
    LBZ and brian991219 Thank this.
  7. LA runner
    93
    25
    Aug 1, 2017
    Thanks
  8. LA runner
    93
    25
    Aug 1, 2017
    Thanks
  9. LA runner
    93
    25
    Aug 1, 2017
    Thanks
  10. LA runner
    93
    25
    Aug 1, 2017
    Thanks
    blairandgretchen Thanks this.
  11. MooneyBravo
    MooneyBravo Heavy Load Member
    865
    1,263
    Feb 20, 2012
    Vermilion, Oh
    For a base layer, you can't beat Under Armour Cold Gear. It's a wicker material that keeps you dry and warm. I wear 1 thermal layer over that and a winter safety jacket and I'm good. It was 0 last time I loaded and had no problems.
    On legs I have the base, 1 thermal if cold enough and sweat pants. Never have any problems.
    I will show you the boots I use. I bought them 1 size bigger and have never had my toes freeze.
    This is the Boa mechanism. You simply push in and turn snug. To open you simply pull and they loosen. Best boots ever. 20180105_235430.jpg 20180105_235527.jpg 20180105_235535.jpg 20180105_235603.jpg
    For gloves I keep about 4 pairs because they all have good points and bad points and all get wet eventually.
    BigBob410, Colorato and Hammer166 Thank this.
