Worried about chicken load
Discussion in 'Refrigerated Trucking Forum' started by slim2none, Sep 21, 2018.
  1. slim2none
    slim2none Bobtail Member
    40
    21
    Jul 26, 2012
    picked up a load of Chicken that was at the right temp of 26 but the box was 30. It was running when I hooked up to it but when I got 100 miles down the road I noticed it wasn’t running any more,so I check and saw that it was on start stop cycle... I thought meat was suppose to be ran on continuous cycle ???
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Continuous is for produce that constantly breathe heat into the trailer. You needed to stay on top of it. (Defrosting is not material to temperature.)
    Frozen loads are less sensitive to stop and go. Reefer will wait a few degrees above setpoint before it cranks up to freeze to setpoint. The one benefit is fuel savings.
    TallJoe and Oldironfan Thank this.
  4. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    I run it on continuous for meat loads but lots of folks run it on cycle. They are typically higher value than the usual produce loads, so I view it as cheap insurance should there ever be a claim. You should be fine.
    TallJoe, Jazz1 and Oldironfan Thank this.
  5. slim2none
    40
    21
    Jul 26, 2012
    Ok cause I switched it to continuous
    Oldironfan Thanks this.
  6. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Cycle is okay on fresh meat loads if the bills don’t specify continuous. Then it kinda becomes driver preference thing
  7. STexan
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    The carriers don’t like continuous loads on drop trailers because they don’t know how long they may sit before being picked up. Maybe 2-3 days which threatens a run out event
    KB3MMX, Farmerbob1, magoo68 and 2 others Thank this.
  8. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    You can always lower you cycle temp to compensate so like 10° lower than called for.
  9. gokiddogo
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    That is horrible advice
    KB3MMX and magoo68 Thank this.
  10. x1Heavy
    34,016
    42,144
    Mar 5, 2016
    Then the carrier is lazy.
    If I was a carrier I would be paying attention to that sort of thing.
  11. Oldironfan
    5,776
    5,544
    May 22, 2017
    Why?
