Carrier Supra 750 Start fail alarm
Discussion in 'Refrigerated Trucking Forum' started by cutfruit, Dec 30, 2018.
  1. cutfruit
    cutfruit Bobtail Member
    My carrier supra 750 will not initiate a start cycle after glow ing. The unit will display a start fail alarm. All fuses are good and I replaced the starter relay, but it appears the unit will not go into start mode and send a signal to the starter solenoid. Please help!
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    If you are loaded and it's been a hour plus you have a very limited time to inform your dispatcher and hot foot to a reefer shop FAST. There is no way you are going to get a timely response in this forum. You might. But get to your dispatcher right away. The load is everything.
    Farmerbob1, REO6205 and cutfruit Thank this.
  4. cutfruit
  5. cutfruit
    The truck is empty, thanks.
  6. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,791
    Jan 17, 2017
    Is it displaying an error code in the alarm screen? If so. What code?
  7. reeferwrencher
    reeferwrencher Medium Load Member
    573
    1,493
    Aug 4, 2018
    Did you jump the starter to see if it cranks?
  8. Anderson11
    Anderson11 Bobtail Member
    Bonjour! Mon camion carrier supra afiche l'alarme AL3 START FAIL. Visage de Que Faire ce problem?
  9. DRTDEVL
    DRTDEVL Road Train Member
    1,706
    3,424
    Jan 27, 2013
    Austin, MN
    Do you see a white, round weatherproof plug in the wire bundle right up front when you open the door? If so, unplug it and plug it back in numerous times. They can lose conductivity over time from corrosion.
