Common air leak location
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Jul 7, 2018.
  1. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    I cant figure out where I have air leak. If truck sits overnight Ill have empty tanks in the morning. I cant hear air leaks and when pressing on brake pedal with brakes released I cant hear air leak.
  3. Judge
    92,280
    Under cab, lines by frame in the cluster of every line on the truck, look under the drivers door at all the lines and figure the one in the middle of your nightmare
  4. Kyle G.
    Kyle G. Road Train Member
    3,901
    20,575
    Jan 23, 2016
    Eastern Iowa
    Check your cab air shocks for small leaks, those can be hard to detect unless you are touching them, but could certainly cause your tanks to drain.
    swaan, 06driver and mitmaks Thank this.
  5. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    Dont know you age, but I am 62 possibly little hard of hearing. I use my grandchildren lol. Spray bottle with soapy water in it. Or a quiet area if you can find one. Every time I listen, a vehicle drives by. Grand kids say..its over here poppy.
    Kyle G., BoxCarKidd and rolls canardly Thank this.
  6. LGarrison
    LGarrison Road Train Member
    1,246
    996
    May 19, 2011
    Sandpoint Idaho
    When I read the title I had to laugh the most common location is at the hole
  7. rolls canardly
    rolls canardly Road Train Member
    1,641
    4,140
    Feb 7, 2009
    mt. pocono. pa.
    I pull out a yellow valve for my parking brake, and had to change that out once
    cause it did the same thing, leaked down overnight.
  8. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    There's probably 10 million miles of air hose.
    Air leaks can be anywhere.
    I've never had a truck hold air over night. And my last OTR vehicle was a brand new FL truck and Reitnour flatbed trailer.
    BoxCarKidd Thanks this.
  9. rolls canardly
    1,641
    4,140
    Feb 7, 2009
    mt. pocono. pa.
    Start at the Air pump fittings with the spray bottle with soapy water, when its all pumped up with air.
    That's how I found mine. Found leak in fittings on my '06 SLC500 Mercedes too, save me from being
    a parts changer. I was about to buy 2 new rear airbags for two grand. For no reason.
  10. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    A gallon sized hand pump sprayer with dish soap works a lot better than a spray bottle.
    If you mentioned what equipment you are running you might get better answers.
    spsauerland and Goodysnap Thank this.
  11. WitchingHour
    WitchingHour Road Train Member
    3,425
    2,144
    Apr 1, 2011
    Broomfield, CO
    Airbags and fittings, leveling valve, there's a 45 degree brass fitting on the top of some Eaton transmissions which likes to crap out, ABS valves and relay valves. cab suspension air bags.. it would help to know which system leaks out first.
