DPF Cleaning Yourself
Discussion in 'Ask An Owner Operator' started by Montanajon, Nov 10, 2017.
  1. Montanajon
    Montanajon Bobtail Member
    35
    16
    Feb 11, 2017
    Just curious if any of you clean out your DPF yourself? If so do you use a pressure washer? Any advice would be great! Thanks
  3. tank4life
    tank4life Light Load Member
    155
    105
    Feb 18, 2012
    Volvo
    D-16, Volvo, took dpf apart and soaked in simple green and rinsed. May take several cleanings to get it clean. 50K miles since removal and cleaning, and no issues. Be sure to get new gaskets and clamps to put the filter back together.
    double yellow and Montanajon Thank this.
  4. againstthewind
    againstthewind Road Train Member
    2,027
    3,164
    Oct 26, 2012
    watched a guy blow one out with a tire bead seater once.
    Montanajon Thanks this.
  5. Montanajon
    35
    16
    Feb 11, 2017
    Great information! Thank you!
  6. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Wow just wow. Funniest post of 2017
    Oldironfan and EZ Money Thank this.
  7. EZ Money
    EZ Money Road Train Member
    Really!! I guess they have never seen how one is actually cleaned in a blast type furnace..
    We buy a new one...have the original cleaned and keep it for the next service interval.....every 250k it gets swapped out and I hope they know the trucks ECM needs updated each time the filter is cleaned..At least on a Cummins.
    Jazz1 and Socal Xpress Thank this.
  8. Ridgeline
    22,752
    124,044
    Better not breath that crap in, you'll be visiting an undertaker.
  9. mitmaks
    mitmaks Road Train Member
    2,588
    2,104
    May 16, 2014
    It needs to be professionally cleaned, just blowing it out with air nozzle you can't properly clean it. You have to measure before/after restriction and possibly bake it as well.
    Entire proper process here...
    Oldironfan and bzinger Thank this.
  10. cmrdev
    cmrdev Medium Load Member
    370
    373
    Oct 13, 2017
    Take dpf off, throw in trash can, remove all the other emissions crap off there and throw in trash too.
    Brickwall, Oldironfan, 6rider and 9 others Thank this.
  11. scottied67
    scottied67 Road Train Member
    10,826
    12,675
    Mar 14, 2010
    california norte
    Just blowing it out will put poisons in the environment.
    Oldironfan and slow.rider Thank this.
