Drive Tires Rotation
Discussion in 'Experienced Truckers' Advice' started by HalpinUout, Jan 1, 2018.
  1. HalpinUout
    HalpinUout Road Train Member
    7,074
    18,165
    Oct 2, 2011
    Just curious to see what mileage intervals do you guys rotate your drive tires? Mine have 55,000 on them don't see any irregular wear or anything like that. If its not broke no need to fix it or should I get them rotated? Thanks.
  3. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    Measure the tread depth with a gauge, usually the right rear drive tires wear faster, so when the tread depth differs, have them rotated. Use the X pattern, right front to left rear, left front to right rear. If your steering axle tires are the same as the drive tires, you can rotate them into the drive axle and put 2 of the drive tires on the steers. Running a tire on the drives for awhile, gets a good wear pattern started, and the tires will wear nicely when rotated to steering axle.
    mitmaks, Hammer166, HalpinUout and 2 others Thank this.
  4. blairandgretchen
    13,933
    76,586
    Dec 9, 2011
    South west Missouri
    I keep a tire wear chart, check depth every 10-15,000 miles.
    When I see a notable difference, then I rotate.
    Typically 50k or so.
    rokue, Oxbow, Dave_in_AZ and 1 other person Thank this.
  5. HalpinUout
    7,074
    18,165
    Oct 2, 2011
    Thank you. Steers are completely different from drives on my truck.
  6. woolybully35us
    woolybully35us Medium Load Member
    313
    550
    Mar 13, 2015
    ks
    I rotate mine every 50,000. front to back then x next time. I got 263,000 miles out of mine last time
  7. bigguns
    bigguns Road Train Member
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    If you use a lug type tire, watch for heel and toe wear. Rotate the tires before the heel/toe wear gets very noticeable to maximize tread life.
  8. Hammer166
    7,605
    27,793
    Aug 18, 2007
    ~8600+' and loving it!
    This works wonders on trailer tires too. Not a problem for most of you, as you can get the shallower trailer treads. The size we run isn't available in anything other than all-position, and that deeper tread is much more prone to irregular wear. Taking 1/3 -1/2 the depth off on the drive really helps.
    Oxbow and bigguns Thank this.
  9. Dave_in_AZ
    424,666
    50,000 on my Yoko's. Had them done on my last PM.
    I have a tire wear thread going lol.
    X pattern. That way they are turning the opposite direction as well for the next 50K.
    I dunno what a TA or someplace charges, but the guy I use through it in with my PM, took him less than an hour.
    HalpinUout Thanks this.
  10. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    I noticed my right rear tires wear out faster too, I thought it was just way my truck is. Is it normal wear pattern then?
  11. bigguns
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    Yes. Right rear wears the fastest. Left front wears the slowest.
