Help !!!!
Discussion in 'Questions From New Drivers' started by Angelo1781, Nov 20, 2023.
  1. Angelo1781
    Angelo1781 Bobtail Member
    Nov 20, 2023
    I need help please, i'm in the market to buy a truck . My previous one was 2015 Volvo VNL 670 with D13, i found a 2019 Volvo with Cummins X15 450 HP and 10 speed automatic eaton fuller transmission 530xxx miles on it and thermo king APU !!! Will you guys advise me to buy it or no ?
    Thank you in advance
  3. Judge
    92,447
    need more info than that.
    Price range, photos,have you had truck checked,?
    Ecm pull?
    oil samples?
    I’ve never had a dyno, but i check everything else, climb under it, go from front to back, etc.
    Flat Earth Trucker and Coffey Thank this.
  4. Angelo1781
    Nov 20, 2023
    Yes i did everything checks up , but i am not familiar with the auto eaton fuller trans are they good or bad ?
  5. Moose1958
    Moose1958 Road Train Member
    15,296
    33,965
    Dec 17, 2010
    Williesburg, Virignia
    The_vett and Flat Earth Trucker Thank this.
  6. Ridgeline
    22,741
    123,673
    What did the dyno/blowby show?
    did you get a dump on the ecm and drive train module?
    any error codes?
    The OA on the trans show any high metal content?
    tscottme Thanks this.
  7. lual
    lual Road Train Member
    5,354
    9,784
    Oct 22, 2020
    SW Georgia
    @Moose1958 --
    Is the above posted video a clip from your living room?
    :biggrin_2559:
    -- L
    The_vett, Flat Earth Trucker and Numb Thank this.
  8. Moose1958
    15,296
    33,965
    Dec 17, 2010
    Ralph is fighting Grady!
  9. Frank Speak
    Frank Speak Road Train Member
    4,583
    14,117
    May 3, 2016
    I don’t care for automatics in general, but I especially don’t like the Eatons. The ones I’ve driven were really jerky in reverse, they’d start off in 1st gear even empty. I’ve even had them jump out of gear in reverse and would have to stop, go to neutral and back into a reverse.
    The only auto that I drove that actually worked pretty much as it should was a DT-12 in a Freightshaker.
    Bottom line, I wouldn’t buy any truck with an auto. Just haven’t had good experiences with them.
  10. Ex-Trucker Alex
    Ex-Trucker Alex Road Train Member
    1,549
    2,704
    Jan 7, 2023
    I was taking this post seriously before he asked this question.....
