Improve anti theft question
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by dreamer2020, Sep 7, 2020.
  1. dreamer2020
    dreamer2020 Bobtail Member
    13
    16
    Sep 7, 2020
    Hello,
    I developed a new anti theft device for cars and trucks.
    While for cars it is easy to implement, i read in a forum that you can jump start a starter.
    How to jumpstart a starter if there is no crank
    I am an electronic engineer, and i do not know too much about cars or trucks.
    I am curious to know, what you can disable in a car or truck in such way that will be imposibile to steal it.
    My device, has in the end a relay with Normal Open contacts.
    My initial idea was to pass the wire from ignition relay through a second relay which is controlled by my electronic circuit.
    But if you can the jump-start the starter, it looks like my device it is not a perfect solution.
    I want to get some suggestions.
    Thank you
    OLDSKOOLERnWV Thanks this.
  3. Ridgeline
    22,724
    123,386
    People have been trying to do this since cars were made.
    there is no way to stop someone from stealing a car or truck, if they want it they will find a way.
    AModelCat Thanks this.
  4. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    There are very good deterrants available, however
    OLDSKOOLERnWV and dreamer2020 Thank this.
  5. OLDSKOOLERnWV
    19,143
    289,461
    The starter can crank the engine all day, but it’s not going to start as long as the ignition side is dead. Don’t worry about the starter, worry about the ignition side of the electrical harness for the engine. If you can control the ignition, you can control the whole vehicle. I’m not much in the way of knowledge for newer computer operated cars, but we all know it needs power to the computer to run.....
  6. Timin770
    1,658
    1,759
    May 27, 2011
    Canton, GA
    Dont forget thievin' tow trucks
  7. blairandgretchen
    13,933
    76,591
    Dec 9, 2011
    South west Missouri
    I have a toggle switch hidden that interrupts ignition power.
    An ECM power wire would work too.
  8. JonJon78
    JonJon78 Road Train Member
    7,241
    43,039
    Jul 1, 2018
  9. Tb0n3
    Tb0n3 Road Train Member
    4,738
    9,652
    Oct 5, 2012
    Earth
    No spark plugs in a diesel. I suppose the fuel pump might be on a different circuit though.
  10. AModelCat
    164,691
    He never said anything about spark plugs. Trucks have ignition circuits too. They control the ECM/injectors on an electronic engine.
  11. dreamer2020
    13
    16
    Sep 7, 2020
    Hi Timin770, can you suggest some so i can see how it was done. My electronics can do it, but my week point is WHERE or WHAT to interrupt ?
    jamespmack Thanks this.
