Leaking wheel seal.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Nov 8, 2018.
  1. mitmaks
    mitmaks Road Train Member
    2,578
    2,093
    May 16, 2014
    Had Petro replace wheel seal on trailer back in spring time. They noticed axle was scarred a bit but not too bad. They said they won't warranty seal job unless I replaced axle. Its not my trailer I just rent it from owner. I sure don't want to spend $1000+ on axle replacement.
    Should I replace seal myself. All the tools and parts would cost me fraction of price what it would cost if I went back to Petro
    They used Step Voyager seal 373-0143. Is that good quality seal?
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,896
    May 25, 2017
    under a shade tree
    have the owner make the proper repairs, or rent from someone else who actually keeps the equipment in good working condition.
    lester Thanks this.
  4. blairandgretchen
    13,640
    74,145
    Dec 9, 2011
    South west Missouri
    I avoid Petro like the plague. Just use an independent shop.
    Bean Jr. and bryan21384 Thank this.
  5. bryan21384
    bryan21384 Road Train Member
    15,425
    33,557
    Sep 18, 2009
    Memphis, TN
    I second that...speaking of seconds, it always helps to get a second opinion.
    blairandgretchen Thanks this.
  6. blairandgretchen
    13,640
    74,145
    Dec 9, 2011
    South west Missouri
    I second that, and also concur.
    bryan21384 Thanks this.
  7. DieselDrivinDaddy
    DieselDrivinDaddy Light Load Member
    230
    531
    Feb 13, 2016
    Poconos, PA
    You can install a Stemco Voyager without any special tools.
    I haven’t had a problem with one failing prematurely when seated properly.
    With my own equipment, I would sand/grind down the scar/burr and ensure there is a proper surface to not gouge a seal or bearing.
    If it’s not your trailer, I would ask the owner what they want done with it and proceed from there.
  8. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    They make a seal saver that you put or drive with spec. tool on the damaged end of axle the seal that comes with repair kit will fit over, this way you can keep from replacing axle tube?
    BUMBACLADWAR Thanks this.
  9. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Sounds like wear on axle shaft leaving "space for seal to leak". On cars they had a cheap "helper bearing seal with smaller diameter" cheaper than axle
  10. mitmaks
    2,578
    2,093
    May 16, 2014
    I've heard Stemco grit guard is better seal.
    jamespmack Thanks this.
  11. mitmaks
    2,578
    2,093
    May 16, 2014
    It says which tools are needed to replace seal right on Stemco website
