My experience at holland enterprises
Discussion in 'Discuss Your Favorite Trucking Company Here' started by Davebox, Mar 21, 2018.
  1. Davebox
    Davebox Light Load Member
    187
    234
    Sep 4, 2016
    I'm currently in orientation at holland, just finished my first day and i figured I'd start a thread since there's not a whole lot of info out there about them. They will get you a rental car to orientation and send you an efs check number to pay for gas up here. Once you get here, you will either be staying at the terminal in one of the driver sleeping rooms or at the red roof inn in fargo. The sleeping rooms at the terminal are actually pretty decent. They even have fairly large flat screen tvs in the rooms. Orientation starts at 8am tuesday morning. You will have your truck assigned to you and do a road test the first day, They also have a van for drivers to use while at the terminal. I will keep you guys updated as i finish orientation and get out on the road.
  3. smokey12
    smokey12 Road Train Member
    1,739
    3,292
    May 30, 2012
    Sounds good so far, good luck!
  4. spindrift
    spindrift Road Train Member
    3,243
    12,919
    Dec 2, 2014
    Texas
  5. Swedish Chef
    Swedish Chef Heavy Load Member
    781
    1,764
    Apr 30, 2013
    Charlotte, NC
    I used to work for Holland myself from August 2015 to May 2016, easily the best trucking company I’ve worked at. The pay is just ok, but they have lots of miles. I’d still be there if they didn’t require 3 weeks out. Good luck!
    Metallica88, jeff18 and Rollr4872 Thank this.
  6. Western flyer
    Western flyer Road Train Member
    2,807
    6,797
    Mar 13, 2014
    Do you get a week off after 3 weeks out.
  7. Davebox
    187
    234
    Sep 4, 2016
    Finished up with orientation today and got my first load. Picking up in big stone city,sd headed to tulare, California. The trucks are very well equipped, but they are governed at 65. So far I'm impressed.
  8. Frank Speak
    Frank Speak Road Train Member
    4,583
    14,117
    May 3, 2016
    Weren’t you at KB? Went sour I take it?
  9. Davebox
    187
    234
    Sep 4, 2016
    Yeah, i left them a while back ago
  10. Swedish Chef
    781
    1,764
    Apr 30, 2013
    Charlotte, NC
    Sounds like Saputo cheese, that’s one of their best customers. By the way, yes the trucks are governed at 65, but if you firmly depress the throttle 3 times, you’ll engage the passing gear, which bumps up the governor up to 70. This helps immensely with passing. It only allows 30 minutes per day at 70 though so use it sparingly.
    Rollr4872 Thanks this.
  11. Davebox
    187
    234
    Sep 4, 2016
    I tried that but it doesn't seem to work on my truck, maybe I'm just doing it wrong
