No drop n hook
Discussion in 'Refrigerated Trucking Forum' started by asphaltreptile311, Oct 10, 2018.
  1. asphaltreptile311
    asphaltreptile311 Road Train Member
    1,480
    2,847
    Jun 16, 2016
    anybody here work for or know any OTR reefer trucking companies with very little drop n hook?
  3. driverdriver
    driverdriver Road Train Member
    4,254
    5,284
    May 30, 2011
    Umm..... Just about all of them.
    Dave_in_AZ Thanks this.
  4. sealevel
    sealevel Road Train Member
    2,664
    10,282
    May 31, 2012
    U.S. 41
  5. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    Some want you to slide your tandems and drop while they unload you, other that some slaughter houses it is rare.
  6. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    I’m at Holland Ent. (Fargo) and we do very little drop and hook. You will occasionally swap with another so somebody can get home on time.
    asphaltreptile311 and Dave_in_AZ Thank this.
  7. 201
    201 Road Train Member
    12,818
    26,391
    Apr 16, 2014
    high plains colorado
    Yeah, never heard of drop and hook reefer. 99% of the time, you load it, you deliver it. Might not be so bad with a load of toilet paper in a van, but I could just see a reefer being sucked dry in a drop yard somewhere.
    Rugerfan and Dave_in_AZ Thank this.
  8. Misesian
    Misesian Road Train Member
    2,078
    3,178
    May 21, 2014
    Nothwest Arkansas
    If you’re interested in a carrier, check them out on saferweb. It will tell you their truck and trailer count. If they’re running a trailer to truck ratio less than 1.5 you’ll see a greater percentage of live unload. I don’t see it as a bad thing unless they’re greater than 500 trucks where you start running into spotty maintenance. I worked as a company driver for Knight Refrigerated and with that many trailers and drivers you run into a lot of issues, not so much with a medium sized carrier.
  9. STexan
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    No. Prime, Schaffer, TransAm, Hirschbach, May, and many other small, large, and medium carriers do LOTS of d/h. Go to any meat plant and note all the different carriers there with drop trailers.
    06driver and Farmerbob1 Thank this.
  10. pmdriver
    2,338
    3,503
    Nov 14, 2017
    Then it is so much of a crap shoot on them drop and hooks at the meat plants, trailers come out all scratched up, sealed and you do not know if it is secured properly. Also it is hard to catch who tore that chute off and put them holes in the walls.
    Farmerbob1 Thanks this.
  11. STexan
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    I agree. That's one the reasons I left the last place I worked prior. I will never work at a carrier again that does a lot of d/h.
    stwik Thanks this.
