No glow plugs reefer unit
Discussion in 'Refrigerated Trucking Forum' started by Onemanshow, Feb 9, 2019.
  1. Onemanshow
    Onemanshow Light Load Member
    103
    64
    Jan 29, 2016
    richmond hill on
    Hey everyone
    At what temperature you think switching from cycle to continuous settings would make more sense if i had to disconnect glow plugs. Running to Alberta so it will be really cold
    Battery is less then a year old CAT. Carrier xtc stealth on 0w30 full synthetic oil.all filters under 1k hours
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    What commodity / temp setting
  4. Onemanshow
    103
    64
    Jan 29, 2016
    richmond hill on
    Lol man again you going into the wrong direction. But let it be.. cucumbers at 50f. So far in Thunder Bay at minus 21 all is good starts right up after like 20 mins off.
    And i set it at 52 for this cold maybe even higher once i make my first drop in Regina. Btw any idea how lablaw works compare to ajax or maple? You know how it can be over there. I stop taking them couple years back already .. Quebec ain't that bad thought.
    Probably without glow plugs its safer to haul produce other then frozen right
  5. gokiddogo
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    You're a lost cause
  6. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Glow plugs or not, make sure you have a fresh high performance battery supporting your reefer no matter what mode you decide to run in. Most newer units have solar charging panels for added insurance for strong cranking power and to trickle charge continuously, regardless of run state.
  7. Onemanshow
    103
    64
    Jan 29, 2016
    richmond hill on
    Oh yeah it's got a cat less then a year deep cycle. On top of that 3 sets of cables, so electrical part is pretty much covered. And its a 2007 model with less then 14k hours on it filled with synthetic oil from New. No egr nor def bs with all bolts on replaced less then two years ago,starter,alternator belts all that
  8. Onemanshow
    103
    64
    Jan 29, 2016
    richmond hill on
    It didn't start after sitting over five days in my yard during extreme cold -28 couple weeks back though.. Lets see how far it can go lol . I will be cautious at 25 degrees point
  9. Onemanshow
    103
    64
    Jan 29, 2016
    richmond hill on
    Dude I agree with you absolutely as well as with most of your posts. Thx for stopping
  10. GypsyWanderlust
    GypsyWanderlust Medium Load Member
    386
    568
    Jan 1, 2018
    If the temp were below 0 I would probably set it to continuous. Even with fuel treatment do you really want to risk the load if it doesn’t restart?
    Farmerbob1 and Onemanshow Thank this.
  11. Onemanshow
    103
    64
    Jan 29, 2016
    richmond hill on
    All right gentleman it went pass 25 degree Celsius and my iron balls started to shrink lol. So it was perfectly safe up to that point . Of course you have to know your equipment.
