QUESTION ABOUT RED LIGHT CAMERAS IN WASHINGTON STATE
Discussion in 'Experienced Truckers' Advice' started by Truckdrivingnew, Aug 27, 2019.
  1. Truckdrivingnew
    Truckdrivingnew Bobtail Member
    14
    7
    Jul 8, 2019
    Hey so I was driving through Puyallup where there are multiple light cameras I was loaded up pretty good (33,000 lbs) and taking off from a light that just turned green before a 2nd intersection with a red light camera (which turned green at the same time) I was still accelerating through the intersection of the 2nd light when it turned yellow ( a very short green light I guess) and I saw it turn red before my cab went under the light. Will I get a red light camera ticket? If I had stopped I would have been in middle of intersection because I was still accelerating (going half the speed limit)
  3. Truckdrivingnew
    14
    7
    Jul 8, 2019
    Is there any rules in Washington state such as if the vehicle is in the intersection when the light turns red it's not a violation?
  4. MACK E-6
    50,104
    239,062
    Don’t worry about it. Camera tickets go to the registered owner of the vehicle, not necessarily the driver. Worst case scenario they’ll just make you pay it and call it a day.
    G13Tomcat and Lepton1 Thank this.
  5. scottied67
    scottied67 Road Train Member
    10,826
    12,675
    Mar 14, 2010
    california norte
  6. G13Tomcat
    G13Tomcat Road Train Member
    11,872
    42,143
    Jun 7, 2011
    Hay Scottie, he would only get a ticket if turning right.....right?!?! ;)
    scottied67 and HoneyBadger67 Thank this.
  7. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    You can contest it if you do get ticket. They do not give you points on record
    G13Tomcat Thanks this.
  8. JReding
    JReding Road Train Member
    1,957
    3,510
    Sep 8, 2014
    Puyallup, WA
    If the front of your vehicle has passed the plane of the stop line before the light turns red, you are legal in Washington state. http://www.bellinghamherald.com/news/traffic/rules-of-the-road/article108421942.html
  9. PE_T
    PE_T Road Train Member
    Some 10 years ago my older sister got a ticket in CA for going through a red light. The documents they mailed her showed pictures of when the light was red and the car was behind the white line where the crosswalk is. I remember she told me that if she had been inside the intersection when it turned red, she would have been legal.
    If you get a ticket, I’d say fight it. There’s a good chance you can beat it, especially if you have a dash cam.
  10. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,525
    May 28, 2015
    I had a similar situation in Fife a year or so ago.
    It was a big intersection, and from a stop, by the time I began to enter it had turned yellow.
    Red before I finished my left turn.
    I saw all the cams flash in the predawn darkness.
    No Tix. I had entered the intersection prior to the red.
    x1Heavy and PE_T Thank this.
  11. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Arkansas light cameras are banned for enforcement, however they do exist everywhere for years for purposes of monitoring etc.
    Im on light cameras with a semi before not too often but usually so big wiping out whatever is on it back in the day. Today they are much better and can see more.
    That stop line is the key. The coil is under there usually. As long that light is not red when you put a wheel on or over it....
