Rears went out while driving
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 85COE, Jan 8, 2023.
  1. 85COE
    85COE Light Load Member
    242
    505
    Aug 6, 2019
    Columbus, Ohio
    I have never had this happen before. How safe is it to try to limp it to a safe haven for a tow truck?
  3. IH Truck Guy
    4,971
    57,737
    Mar 2, 2008
    Purgatory
    It depends.
    Will it move at all or do you need to lock the power divider in?
    Another Canadian driver and cke Thank this.
  4. 85COE
    242
    505
    Aug 6, 2019
    Columbus, Ohio
    It will move with or without the power divider lock in. Right now I'm cruising along with the power divider locked, at about 5 to 7 miles an hour trying to get to a safe haven, which is about 13 miles away
  5. 85COE
    242
    505
    Aug 6, 2019
    Columbus, Ohio
    Also, I am loaded, total of about 72 to 73,000 lb, and I don't really hear very much clunking anymore
  6. 85COE
    242
    505
    Aug 6, 2019
    Columbus, Ohio
  7. blairandgretchen
    13,964
    76,793
    Dec 9, 2011
    South west Missouri
  8. bad-luck
    bad-luck Road Train Member
    3,440
    6,337
    Nov 16, 2013
    Baltimore, Maryland
    Is any oil leaking on the ground?
  9. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    Honestly if your truck will move on its own power and you heard clunking and carrying on the damage is done.
    Just get to wherever you are safe and forget about those rears.
    Those rears are so ancient you may have a hard time finding internals for them even for someone to rebuild them and honestly because it's all ancient and there's probably Spring Ride on there if you have the money go get yourself a nice later model air ride cut off and get it on that truck.
    For what it would cost you to have someone work on them it's just not worth it for something that ancient honestly even if you could find the parts.
    Not only will your back and body thank you, anything that you need for them you'll just make one phone call and you'll have it that day or the following.
    Sorry to hear about your troubles but if you can afford it it's a really good opportunity to upgrade.
  10. 85COE
    242
    505
    Aug 6, 2019
    Columbus, Ohio
    30 Westbound just before Indiana
    Nothing beyond the normal. There's no new leaks
    I was looking at having the rears changed out, the biggest thing was the cost, and finding a set that would go well with it
