satellite Radio models
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by evd, Jun 23, 2014.
  1. evd
    evd Light Load Member
    130
    90
    Apr 23, 2012
    Reading PA
    would like to know what is best satellite radio out there for trucks?
    there few models and I don't know which better on the road.
    and how I can install antenna with out any alteration like drill to the truck ?
    thanks in advance for any help.
  3. tkpinsc
    tkpinsc Light Load Member
    52
    58
    Nov 2, 2013
    First you need o decide which set of channels you want, Sirius or xm, and choose a compatible radio. I got mine with a heavy discount from Sirius when I signed up for a year of service.
    I have a Sirius 6. I simply lay the antenna on the dash of my cascadia. Occasionally lose the signal when travelling a certain direction but it comes back in a few miles.
    Only model I've used except one that's built into my car so I don't know how it compares.
    evd Thanks this.
  4. nightgunner
    nightgunner Road Train Member
    2,112
    2,783
    Jul 23, 2013
    Cedar Rapids, IA
    I still use my XM Roady 2 that I got from Walmart back in '05 or '06. Honestly they all do the same thing. No reason to spend a lot of money because of how it looks. Just find the cheapest one on sale.
    evd Thanks this.
  5. Balakov100
    Balakov100 Road Train Member
    3,934
    2,627
    May 10, 2012
    Temple, TX
    I will disagree with that somewhat.
    If you can find one that has the 1 hour (?) recording.
    That's really nice to have.
    And TuneSelect.
    The recording records the last hour automatically of whatever channel you are listening to.
    So basically that allows you to Pause shows
    And the Tune Select let's you 'memorize' songs and it will tell you whenever a certain song comes one, and you will be able to jump to it with a key press.
    If I was looking for a new XM Radio these would be a must.
    I had the SkyFi2 and really miss the recording.
    blairandgretchen Thanks this.
  6. w.h.o
    w.h.o Road Train Member
    3,492
    3,879
    Jan 10, 2011
    Chicago, il
    I have xm onyx *I think that's how is spell* and it has that one hour recording. I can go back a hour and listen again or repeat a song. useful on comedy central channel and skipping the ads. love it.
  7. blairandgretchen
    10,471
    48,893
    Dec 9, 2011
    South west Missouri
    I have the basic Onyx and its . . . basic.
    I like the recording feature on the upgraded one.
    They're all cheap junk from China that doesn't withstand the vibration after time.
  8. Richter
    Richter Road Train Member
    4,090
    1,691
    Feb 13, 2012
    Philadelphia Pa
    Your truck doesn't have built in XM? Most cascadias do.
    I ran my antena out the passenger door and mounted on the cb antenna base. You drive an evolution which has no upper bracket for miror or cb antennas which is why i though it was built in. You can put it on your dash....you can also double side foam tape it on the roof running wire out passenger door frame. Dash works half way decent but you will loos signal on road with tall trees on right. (i76 in pa, parts of i 80 on oh all of WV.)
    evd Thanks this.
  9. STexan
    STexan Road Train Member
    14,962
    29,118
    Oct 3, 2011
    Longview, TX
    I have XM but I've heard Sirius tuners pull off of different satellites that are better situated to give optimal performance across the continental US, including the northeast. With XM and a less then optimal antenna location, the further east and north you go the more leaves and hills will obstruct your signal. Back before Sirius and XM merged, it is said Sirius had the better satellite setup and I'd assume everything still runs the same, depending on whether you have an "XM" account/radio or a "Sirius" account/radio (Yes, I realize they are the same company) Can anyone back this up?
    And yes, a lot of trucks today have radios with integrated XM/Sirius tuners and antennas and these are great if you get one, but in these cases it is on the driver to activate and pay for the subscription
    evd Thanks this.
  10. evd
    130
    90
    Apr 23, 2012
    Reading PA
    I drive regional Va ,WV ,NY ,RI ,MA,CT and PA hope to get the most signal I can in those area.
  11. Richter
    4,090
    1,691
    Feb 13, 2012
    Philadelphia Pa
    I though that all serios/xm sats now broadcast both and thus it deosnt make a difference.....could be wrong tho. In either case, antena placement makes a big difference. Mount as high up on the truck as you can.
  • Draft saved Draft deleted
