Detroit 60 series 500 hp set at 470 torque 1750 super 10 overdrive and these rear ends in it 2:64 22.5 tires . It turn 1225 @ 67mph It’s spec to run 72 mph
Specs
Discussion in 'Refrigerated Trucking Forum' started by Gypsy38916, Jul 24, 2018.
I have a detroit 60 series 450 horsepower, with a converted 13 speed in a 2003 Columbia with no side skirts and exhaust behind the doors. @67mph I'm at 1400rpm. @70mph 1475rpm. I average 6.7mpg flatland, 5.5mpg mountains @70mph. Flatbed with 1.9mill miles.
I personally feel my truck is too long legged. Truck really pulls hills at 1200rpm. -
With those specs you need to drive it in direct and at 60 you’d be around 1450. The older motors run well at 1450-1550. You’d then have top gear overdrive if you’re empty or running from the cops.
do any reefers run sliently?
Oxbow Thanks this.
That's like " Do pigs fly?' & Yes sometimes they do; in a plane as a service pig.
You pretty much have to have an engine of fair size on a reefer trailer that you expect to keep at produce temperatures or less, in summer temperatures. That's a lot of space to cool, and a large temperature differential.
Straight truck reefer units are sometimes compressors only, powered by the engine of the truck, since the truck is not articulated. That compressor will still make *some* noise, but not as much as a model with an engine.
