Tanks not equalizing
Discussion in 'Peterbilt Forum' started by krazzyboi_44, Jan 23, 2026.
  1. krazzyboi_44
    krazzyboi_44 Light Load Member
    298
    42
    Apr 30, 2008
    BAton Rouge,Louisiana
    I have a 389 peterbilt with a paccar, The fuel is being pulled from the drivers side tank filling up the passenger side. A couple days ago I unlatched the drivers side fuel cap while I was on my 10hr break. The tanks leveled out and started back working. Now its doing it again. How can I fix this?
  3. JB7
    JB7 Road Train Member
    1,018
    1,804
    Dec 13, 2022
    Laurel, MD
    Sounds like a venting problem. Check any vents. Some fuel caps are vented so it may be a bad cap. Switch the fuel caps if you can and see what happens.
    Rideandrepair, '88K100 and Oxbow Thank this.
  4. Judge
    92,075
    Find vent tube on top. Run small stick or metal clothes hanger to clear blockage. Dirt dobbers have blocked them tubes too
  5. blairandgretchen
    13,933
    76,586
    Dec 9, 2011
    South west Missouri
    Or splitter valve on return.
    Rideandrepair and Oxbow Thank this.
  6. '88K100
    '88K100 Road Train Member
    1,490
    3,589
    Aug 23, 2020
    The vent is frequently the culprit as many hang between tank and frame and get packed with ice during inclimate weather
    Dumping fuel conditioner in tanks can free up the splitter valve, or just park in heated shop overnight to defrost everything
    Rideandrepair and OldeSkool Thank this.
  7. Tall Mike
    Tall Mike Road Train Member
    7,689
    36,835
    Aug 20, 2014
    New York State
    I had that happen on a Junkliner Classic XL I owned in the late 90's.
    A plugged vent hose was the culprit.
