Thermo King coolant leak
Discussion in 'Refrigerated Trucking Forum' started by vinsanity0, Nov 10, 2018.
  1. vinsanity0
    vinsanity0 Light Load Member
    73
    82
    Jun 26, 2016
    We've had this problem with two trailers. Older units. They run fine, but when shut off they leak coolant. No leaking at all while running.
    Had TK in Albuquerque check this one out .They couldn't find a leak. They replaced the cap but that didn't fix it.
    Is this just a coincidence that both Thermo Kings do this? Is there something we are doing wrong?
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Where does it leak from when shut off. Can you determine that? Is it making a puddle of coolant wherever you park it?
  4. vinsanity0
    73
    82
    Jun 26, 2016
    I can't see where it's coming from. It doesn't just start pouring out when I shut it down. It usually takes awhile. Then it covers the catwalk as I'm driving. It usually stops around the sensor but doesn't seem to be coming from there. Both units did this.
  5. iceman32
    iceman32 Medium Load Member
    564
    699
    Sep 26, 2014
    It’s probably one of the hoses. Depending on what Unit model you have, the hose locations can vary. Some are behind the firewall or inside the reefer. A service provider will need to literally take everything apart and it’s not a 1 day job.
  6. reeferwrencher
    reeferwrencher Medium Load Member
    613
    1,577
    Aug 4, 2018
    What model of tk reefer is it?
  7. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,794
    Jan 17, 2017
    My guess is a temperature related leak. When the unit is hot and everything is expanded from heat, there is no leak. When the unit cools, something is contracting enough to create a leak.
    It might be a crack, but I suspect it is an old seal. I am completely unfamiliar with reefer unit construction, but the first thing I would check are o-ring seals if there are any.
    Snailexpress and SteerTire Thank this.
  8. buzzarddriver
    3,833
    11,594
    Feb 1, 2011
    Dallas, TX
    Gets some UV Coolant leak detector fluid and then look with a UV light to find the leak. As FarmerBob said. It is leaking from a crack that opens up when the unit cools off.
    Farmerbob1 Thanks this.
