Truck jerking while turned off
Discussion in 'Ask An Owner Operator' started by Schöne, Mar 3, 2022.
  1. Schöne
    Schöne Bobtail Member
    47
    20
    Feb 23, 2019
    Hi my Volvo jerks when parked and turned off. It almost feels like I'm being rear ended. I don't know whether it's the truck or the trailer. What could be the problem?
  3. nikmirbre
    nikmirbre Road Train Member
    5,593
    10,362
    Jul 27, 2011
    High Point NC
    I read the title totally wrong.......
  4. loudtom
    loudtom Road Train Member
    1,717
    2,806
    Aug 26, 2016
    When the air bags deflate, it can feel like that.
    Concorde, dunchues, Oxbow and 8 others Thank this.
  5. blairandgretchen
    13,977
    76,867
    Dec 9, 2011
    South west Missouri
    I’d tell the truck it’ll go blind doing that . . .
    autopaint, Hulld, mud23609 and 24 others Thank this.
  6. diamondd817
    diamondd817 Light Load Member
    159
    560
    Oct 11, 2020
    Yea, probably should edit that title.
  7. Ffx95
    Ffx95 Road Train Member
    1,370
    2,635
    May 18, 2017
    Oh yeah I would get turned off too :biggrin_25523:
  8. Magoo1968
    Magoo1968 Road Train Member
    2,061
    5,492
    Mar 18, 2021
    St Malo mb
    As stated above you have a air leak causing airbags to deflate .
    Schöne, Oxbow, D.Tibbitt and 4 others Thank this.
  9. God prefers Diesels
    4,198
    22,265
    Jun 26, 2020
    South Texas
    When the airbags inflate and deflate, the axles rotate some. So when you're sitting there with the bags slowly deflating, your brakes are set, and they try to keep the axle from rotating. But once the bags hit a certain pressure, they aren't helping anymore, and the brakes can't do it all by themselves, so they slip and the axle rotates a little bit until the combination of brakes and airbag is enough to stop it from rotating anymore.
    Rinse and repeat this process until the axles have moved as far as they are going to. If you want, you can release your brakes, dump your airbags, and reset your brakes. It will bypass the "lurching" process.
  10. supersnackbar
    20,165
    53,123
    Aug 19, 2007
    Your Town, USA
    Not sure if Volvo's are like Macks since they're the same company, where the dump switch only works with the key on. On a Mack, if you turn the key off with the switch in the dump position, it closes the dump valve and the bags reinflate.
    If you have an air-ride trailer, set your trailer brakes 1st, then let the trailer airbags settle before setting your truck brakes. If you don't have an air-ride trailer then the only thing to do is find the air leak and have it repaired.
    Oxbow, D.Tibbitt, loudtom and 4 others Thank this.
  11. God prefers Diesels
    4,198
    22,265
    Jun 26, 2020
    South Texas
    LOL, why do manufacturers have to complicate things? I guess I need to realize not everyone is driving the same janky POS as me.
