x chains
Discussion in 'Flatbed Trucking Forum' started by ford06, Aug 19, 2017.
  1. ford06
    ford06 Bobtail Member
    39
    13
    Mar 8, 2017
    do x chains on plate steel count as your first 2 securements in 5' and your last 2 if you x chain the back also
  3. Espressolane
    18,711
    117,319
    Think along this path.
    Tools.
    Tools are things like bulkheads, stakes and other devices and equipment that does not have direct securement of the cargo. They are containment, and improve the safety of the load.
    Securements
    securements are in direct use of preventing movment of cargo. usually in some form of direct contact with the cargo. The clamping forces.
    wondering about the first two securements in 5 ft you mention. From a company policy?
  4. blairandgretchen
    13,971
    76,820
    Dec 9, 2011
    South west Missouri
    Don't know whether it counts or not.
    If it's a flat guillotine, then you bet I'll have cross chains on the front.
    Scares me when I see guys without it on plate steel.
    ford06 Thanks this.
  5. DrFlush
    DrFlush Road Train Member
    1,297
    2,707
    Mar 22, 2011
    Upstate NY
    Personally I K chain flat steel, but if your using two binders and chains they would be hard pressed to not accept it as two in the first ten.
  6. Gentlemanfarmer
    Gentlemanfarmer Medium Load Member
    365
    384
    Feb 26, 2010
    Greenville, FL
    If I read FMCSR 393.106(d) and 393.110 correctly, then yes, your x chains on steel plate would count as your first two tie downs on the first five feet. Then you would need one tie down for each additional 10 feet.
  7. Tb0n3
    Tb0n3 Road Train Member
    4,738
    9,654
    Oct 5, 2012
    Earth
    There is no "2 straps for first 5 feet" rule. The only rule there is between 5 and 10 feet 2 straps are required, but under 5 feet and under 1100lbs one may be used.
    rank Thanks this.
  8. Gentlemanfarmer
    365
    384
    Feb 26, 2010
    Greenville, FL
    FMCSR 393.110(2i) Two tiedowns if the article is: 5 feet or less in length and more than 1100 pounds in weight: or (ii) Longer than 5 feet but less than or equal to 10 feet in length, irrespective of weight. (3) Two tiedowns if the article is longer than 10 feet and one additional tiedown for every 10 feet of article length, or fraction thereof, beyond the first 10 feet of length.
    rank Thanks this.
  9. Tb0n3
    4,738
    9,654
    Oct 5, 2012
    Earth
    Yeah, I read it, but nowhere does it say 2 straps in the first 5 feet of a load.
    rank and kylefitzy Thank this.
  10. DDlighttruck
    DDlighttruck Road Train Member
    1,386
    19,919
    Dec 12, 2015
    Generally I don't include X chains guts bellys or chokes in my aggregate or length calculations. I usually try to secure it for length or weight rules, then add driver safety.
    rank, TripleSix, Dye Guardian and 3 others Thank this.
  11. ford06
    39
    13
    Mar 8, 2017
    i agree but it seems to most they question it
