04 T600 bumpy ride between 55-60 mph when bobtail or light load?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by russtrucker, Apr 16, 2019.
  1. russtrucker
    russtrucker Road Train Member
    1,767
    337
    Mar 27, 2012
    Central PA
    My dad's 04 T600 has that bumpy feeling when truck drives between 55-60 mph. Bobtail and light weight loaded. Had that same bumpy/jumpy ride since he bought that T600 back in 2011. All suspension components had been replaced. So as tires. Tried that with and without centramatic balancers. Shocks were replaced. Good alignment. The only parts we haven't replaced since purchasing that T600 is drive shaft and some u-joints. What could cause all that despite changing parts?
  3. boneebone
    boneebone Road Train Member
    2,297
    2,371
    Mar 13, 2009
    Replace the front cab mount bushings and cab shocks.
  4. russtrucker
    1,767
    337
    Mar 27, 2012
    Central PA
    We got those replaced a while ago. Still does the same bumpy feeling.
  5. Goodysnap
    Goodysnap Road Train Member
    3,749
    9,121
    Jul 12, 2017
    Have you considered the possibility that it's just the way it is and maybe theres nothing broken or worn. What are you comparing it too?
    Big Road Skateboard Thanks this.
  6. russtrucker
    1,767
    337
    Mar 27, 2012
    Central PA
  7. Goodysnap
    3,749
    9,121
    Jul 12, 2017
    Suspension and cab ride height? Axle angles within spec?
    The description "bumpy ride" doesnt offer much, thus the lack of response.
    Is it a vibration or is it harshness of the ride quality when hitting imperfections in the road surface?
    062 Thanks this.
  8. russtrucker
    1,767
    337
    Mar 27, 2012
    Central PA
    harshness of the ride quality between 55-60, on any road surface.
  9. 062
    062 Road Train Member
    6,291
    33,838
    Oct 20, 2013
    How much play is in pinions? They can cause it to feel like a tire out of round. Carrier bearing generally will be there all the time after a certain speed, but you never know.
  10. russtrucker
    1,767
    337
    Mar 27, 2012
    Central PA
    Well, we haven't touch the differential axles yet other than changing gear oil. Maybe. Drive shaft and differential are the possibility since we haven't done work on em other than lubing.
  11. Soon2BeOwnerOperator
    Soon2BeOwnerOperator Light Load Member
    102
    51
    Feb 13, 2019
    New Hampshire
    Did you ever figure it out? Could it be a kingpin needing replacment?
