06mxs acert c15 boost problems
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Gunsmoke77, Apr 27, 2019.
  1. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    7000 lbs of turbos hanging off four 3/8" studs. My money is on a broken turbo/manifold stud.
  3. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Technically only one turbocharger is weighing on the manifold, and it's the smaller of the two. The lower turbo mounts to a bracket which is bolted directly to the block.
    swaan, pushbroom and spsauerland Thank this.
  4. lilillill
    5,642
    13,472
    Nov 7, 2007
    Is a BXS turbo setup different than an MXS? I was positive it was the big one that was bolted to the center section of the manifold.
    My NXS is at home so I can't look at that one either.
    Oxbow Thanks this.
  5. lilillill
    5,642
    13,472
    Nov 7, 2007
    Nope, you're right... my bad. Just dug up some pictures of when I replaced the studs on the old BXS and it is the smaller one.
    Oxbow and Goodysnap Thank this.
  6. Guntoter
    Guntoter Road Train Member
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    They are bolted in two different spots. Screen Shot 2020-08-05 at 7.30.47 AM.png
    Brettj3876 Thanks this.
  7. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Guntoter Thanks this.
  8. Guntoter
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    Thank you sir.
    ready2truck and Brettj3876 Thank this.
  9. Chucksaxton
    Chucksaxton Bobtail Member
    6
    Aug 19, 2020
    I had the sam
  10. Chucksaxton
    6
    Aug 19, 2020
    I had same problem on an international 9900i with c-15 cat. I have 30 years experience in heavy duty truck repair, and this one like to have drove me crazy. Finally found the problem, my air charge cooler was stopped up on the inside. Took it off used some aluminum bright on the inside and pressure washed it. Before washing with a load I could not build 4 or 5 boost ,after almost 30 psi.
