07 Cat MXS 475hp code 290-5 active
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by RUSTBOXF700, Apr 11, 2023.
  1. RUSTBOXF700
    RUSTBOXF700 Bobtail Member
    12
    19
    Mar 23, 2023
    Truck came in with engine protect coming on. 07 Freightliner with c-15 mxs. Only codes in ecm were active 290-5 and inactive 290-7. 290-5 had 255 occurrences recently. Performed valve test and all were good except for #6. Removed valve cover and inspected wiring. Found no faults in wiring from ecm to valve. Assumed valve is bad and replaced with new. Cleared codes and drove truck, got back to yard and 290-5 code is already active. Any suggestions on were to go from here?
  3. bjytech
    bjytech Light Load Member
    245
    222
    Nov 9, 2013
    290-5 is open circuit on #6 intake valve actuator, since you already replaced the actuator, and all other wiring seems to be fine, I would replace the plug end that goes into the actuator, they have a lot of issue from the heat and oil they see. Cat repair kit for the plug is part# 366-9748.
    Oxbow and singlescrewshaker Thank this.
  4. RUSTBOXF700
    12
    19
    Mar 23, 2023
    That did it, the connector was bad. Thanks
    bjytech and Oxbow Thank this.
