07 cm870...
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TruckerPete1990, Jun 1, 2017.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    I've been having a problem with coolant lost... it's an internal leak.. it's not my egr stuff... My sodium has been in the 20s my potassium has been in the 70s.. it's been this way for months. Any ideas? I find it weird how the numbers been almost the same every time... here is my oil samples don't worry it's not my address or number lol. I'm adding about 1 gallon of coolant every 25,000 miles...
  3. 86mechanic
    86mechanic Medium Load Member
    372
    62,172
    Sep 6, 2016
    Northridge, CA
    Maybe a leaking Injector cup
    TruckerPete1990 Thanks this.
  4. Hogleg
    Hogleg Medium Load Member
    311
    258
    Nov 20, 2016
    Salem, Illinois
    We get a weep out of the back of the water pump occasionally. Not all the time but enough to slowly use coolant.
  5. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    thats what i was thinking it is too...
  6. 86mechanic
    372
    62,172
    Sep 6, 2016
    Northridge, CA
    You could drop the oil pan and see if you can see coolant traces on one of the cylinders
  7. 86mechanic
    372
    62,172
    Sep 6, 2016
    Northridge, CA
    Could also be a small leak on a liner
  8. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    any idea what the cost maybe to get the injector cups tested?
  9. 86mechanic
    372
    62,172
    Sep 6, 2016
    Northridge, CA
    Not sure! Anyway, after thinking about it you said you had coolant in your oil, so it be more likely that it is a liner then a cup. Because if it was a cup you would have fuel in the coolant.
  10. TruckerPete1990
    8,623
    5,382
    Jul 16, 2012
    Hmm hope it's not a liner maybe I'll get lucky and it's a sleeve lol
  11. kwswan
    kwswan Road Train Member
    2,020
    11,017
    Jul 26, 2009
    mcminnville,tn.
    A liner & a sleeve are the same thing.
