07 International 9900i ign problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by AlekseyP, Jul 2, 2016.
  1. AlekseyP
    AlekseyP Bobtail Member
    Hi I went to start my truck today and after turning ignition to first position my F7-A fuse blow out I reset it and try ed again still same problem any idea what could be cousin the problem F7-A responsible for "key switch circuit & Related relays for ignition & ACC. Any help would be appreciated. Thx
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    This is the basic power feed to your key switch, then that power goes out to several different circuits. Does this do this in the accessory position? If so, it is accessory related. Try to remove the ignition relay and see if the breaker pops. If it does, something must be shorted between the key switch and breaker panel since no other breakers are popping. Could also be the key switch itself shorted internally.
    AModelCat and AlekseyP Thank this.
  4. 1mm3406e
    1mm3406e Bobtail Member
    28
    13
    Jul 13, 2019
    Did you ever fix this, I have 05 9900 with same problem. I replaced both solenoids and all fuse and relay are good. I’m gonna just bypass it by putting a push button in the truck.
    broke down plumber Thanks this.
  5. broke down plumber
    4,066
    32,080
    Jan 25, 2024
    Smart and eazy way to fix .
