Since ive been pulling for ats, ive seen some loads that say 1/2 inch chains required. Military stuff. D rings and cut outs on the rgn trailers arent rated to g70 1/2 chain. Does anyone carry 1/2 in chains? Or just use more 3/8? Im thinking about buying 20ft chains and cutting them on half. Id have 4 10ft with one hook each. And yes ive got snap binders rated at something like 9200#s. If i use them often id buy rachets.
1/2 in chains
Discussion in 'Flatbed Trucking Forum' started by northernhopper, Oct 14, 2016.
Page 1 of 6
Ratchet binders are the way to go. You broker through them or work for them
Go to midwest steel north of U Haul on Lincoln Av in St Cloud for tie down gear -
How small are you're D rings to not be rated for grade 70 1/2"? I carry 8 1/2" X 3' chains on my 55 ton and 12 1/2" 10' to 16' chains on my 9 axle. My 3' chains have grab hooks on one end and slip hooks on the other, I love them.Oxbow, snowman_w900 and northernhopper Thank this.
Im doing what they call a lease. I call it a rent. I live an hour from St. Cloud. Fleet farm has the chains. Closer to home. Are they needed? Should i get 4 10ft? One hook or two per chain?
I agree on the rachets. Ive already get snaps though. -
The only time i checked was a tandem stretchable rgn. Sticker said d rings were 6600 i think. Cutouts 9200? Both less than 1/2 chain
How often you use the grab hooks?
It only took me one forehead gash and a concussion later to leave those snap binders to the professionals. I would get the 1/2" you may use them few times a year you always have to be able to do what the other guy can't.
Most D rings on lowboys I've pulled are 15,000 rated I've never measured the diameter of the ring but they're probably close to an inch.
Daily. -
I agree. Thats the way im leaning. I'll buy chains when i get home next week. You think 4 10ft enough? Buy 3 20s and make 4 10s and 5 4s out of them? Ive had the snap binders for years.
The rings were probably an inch. Sticker said 6600. Im guessing that the welded strap holding the ring was the weak point?
Page 1 of 6
