10 meter radios
Discussion in 'CB Radio Forum' started by Roughneck08, Feb 12, 2018.
  1. Roughneck08
    Roughneck08 Bobtail Member
    29
    7
    Jan 15, 2018
    Centerview, mo
    I am wanting a different radio. Are the 10 meters able to get 11 meter channels or do I have to take it some where to get that added. I have been looking at Stryker' s in particular. But for what I do I need several normal cb channels for shippers. I have never had anything other than a cobra radio so my knowledge of the the other types is limited.
  3. 715
    715 Light Load Member
    95
    72
    Feb 11, 2018
    GA
    I have a Stryker 655 and it's been modified for 11 meters. You have to take the radio to a CB Shop to have it modified all depends on the pricing at the shop where you buy the radio at or take it to another shop. Only difference between the 655 and 955 the 655 don't have sideband and the 955 has sideband. Sideband is a great when the skip/conditions rolls in to the area you're currently in.
    Roughneck08 Thanks this.
  4. delta5
    delta5 Road Train Member
    1,193
    7,404
    Sep 9, 2010
    10m radios need a minor change on the circuit board. Usually removing a resistor. The rci ranger 2950 and 2970n2 have a small plugin circuit board that goes into a socket on the back of the display. Turn the radio back on and cb channels will work, along with the 10m and 12m bands.
  5. Roughneck08
    29
    7
    Jan 15, 2018
    Centerview, mo
    So it won't work on 11 meter channels strait out the box
  6. 715
    95
    72
    Feb 11, 2018
    GA
    Yes, Correct it won't work on 11 meters out of the box unless it's been modified by the shop before they sale it.
  7. delta5
    1,193
    7,404
    Sep 9, 2010
    No. Maybe someone can chime in. I think those Stryker radios need a resistor removed.
  8. Roughneck08
    29
    7
    Jan 15, 2018
    Centerview, mo
    Does anyone know a shop I can buy one from and have them do that to it. I know clayys won't the tech told me we can't do it it is illegal
    Tall Mike Thanks this.
  9. delta5
    1,193
    7,404
    Sep 9, 2010
    If the shop re-aligns it for 11m, you may lose a bit of performance on 10m. But if you are not a ham, then no worries.
  10. Roughneck08
    29
    7
    Jan 15, 2018
    Centerview, mo
    Ok just have to find one that does it thanks for the help
  11. delta5
    1,193
    7,404
    Sep 9, 2010
    There aren't many shops that I would recommend as most are hacks. Especially for the Strykers. They are complicated with very small surface mounted parts. The hack shops usually wind up damaging the circuit board traces while doing junk mods.
