10spd VS 9spd, what changed?
Discussion in 'Experienced Truckers' Advice' started by clayshot, Nov 17, 2013.
  1. clayshot
    clayshot Light Load Member
    115
    78
    Oct 30, 2013
    near Philly, Pa.
    I'm about to get back in a truck after a lot of years gone by. The only thing I drove was a nine speed.
    Did they just redesign the whole trans or just add one to the top end? I realize much has changed with computer technology now running internal systems. Is 10 more a cruising gear than anything else?
    Heck, I started driving an early 80's mack day cab back in the early 90's and that was a single axle 6 SPD. LOL {no power steering} That truck should have been put out of it's misery long before I ever got it. :biggrin_25523:
  3. DsquareD
    DsquareD Road Train Member
    1,439
    857
    May 21, 2009
    Green Bay, WI
    The last truck I drove had a 9 speed and my current truck has a 10 speed. The first few days I was in this one I wanted to skip 6th as that is the only difference in the shift pattern (6th on a 10 speed is in the same spot as 1st on either one). If the truck is set up right top gear will be your cruising gear on either one.
  4. 15 over
    15 over Light Load Member
    84
    45
    Jul 1, 2013
    Mobile, Al
    A 9 speed has basically a granny gear on the low side that you can't shift into in high range, 5 gears in low and only 4 in high. A 10 speed is the same in high and low, 5 and 5. Basically a 9 speed is just a 13 that you can't split the top range. Unless you are talking about a super 10, then it gets really confusing.
  5. Saddletramp1200
    Saddletramp1200 Road Train Member
    2,111
    2,836
    Sep 4, 2011
    Houston Texas,USA
    No body I know of uses 1st gear. I skip gears myself. Really depends on how much weight your pulling.
  6. 25(2)+2
    18,758
    45,935
    Sep 18, 2006
    the road less travelled
    Not that much difference, I liked a 9 better, but haven't driven 1 in a very long time. It's a big jump skipping 6th when you are loaded, so it soon cures you of doing it.
    I skip gears all the time going down hill and if I have to pull a hill before shifting, I shift 2 at the top for the most part, whichever gears it involves.
  7. passingthru69
    9 speed? Oh tht was for the freight haulers.. I miss my 10 x 4, 2 stick
    Now only running an 18 speed
  8. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    I'll take a 9 over a 10 any day. I've got an 18 same pattern as a 9 have driven a truck with a 10 speed before and they're a royal PITA. Missed 6th gear more times than I could count finally got it down. Got back in my truck kept trying to go back into low after I went to the high side. Ugh. And don't get me started on one of them cluster #### super 10s.
    Eaton "the super 10 is the preferred transmission of the professional driver"
    I'm not a professional I guess. I'll keep my 18spd. That super 10 is nothing but a pain. No range selector only a splitter yea not right. And now they come with an auto shift top 2 gears. That'll scare the living piss out of you when that tranny decides to drop a gear on you and you're not expecting it. Guess it comes in the same format for an 18 too. Wouldn't know don't care to. I'll put a 9spd direct drive in my truck before I put something it in that shifts automatically.
  9. wore out
    wore out Numbered Classic
    17,222
    213,065
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I still run an old double over 13 high gear is up against the dash. I get in another truck no big deal I automatically run a standard pattern. Get in a 10 or 15 speed become a newby again. I guess cause I never use loe gear in anything hardly its just unnatural to hit it in high range. Super 10 is a curse on the earth as far as I'm concerned.
  10. Shaggy
    Shaggy Road Train Member
    3,116
    2,595
    Sep 21, 2006
    FIGMO
    Only thing awesome about a 9 speed. can not forget the pattern to a
    18 speed :)
    Depends on which ( 10 speed ) can you elaborate OP ?
  11. Shaggy
    3,116
    2,595
    Sep 21, 2006
    FIGMO
    Agree with the super 10. Everyone has opinions and they should burn with the sun for ordering a super 10 lol.
